Small Block (380ci) turbo/blower 1200-1300hp #2415261
12/08/17 03:21 PM
12/08/17 03:21 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Hi Guys,
Bouncing around the idea of building a Mini mod for Pulling. Engine rules are:
All small block engines at 380ci max with either 671 at 30% overdrive or 871 at 20% overdrive.
Single turbo at 83mm.
Need around 1200-1300hp and try and keep the engine as light as possible.
What the best options here for us Mopar guys?
Thanks,
Doug
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415274
12/08/17 03:50 PM
12/08/17 03:50 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
is the gen 3 hemi considered a small block? a 6.1 is 370cid and Mopar has an aluminum block.
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415275
12/08/17 03:51 PM
12/08/17 03:51 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
What block are you using
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: CTD5.9] #2415278
12/08/17 03:54 PM
12/08/17 03:54 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
This! A 5.7 .020 over with a 3.9 stroke. 379 cid.
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: CTD5.9] #2415282
12/08/17 04:15 PM
12/08/17 04:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would be perfect for him... they are strong
and fairly light
wave
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: MR_P_BODY] #2415306
12/08/17 05:01 PM
12/08/17 05:01 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
and fairly light
wave
Ok so can we make 1200-1300hp with a gen 3 Hemi and the turbo or blower set ups that my class is allowed?
And yes they do consider the Gen 3 hemi as a smallblock
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: pittsburghracer] #2415313
12/08/17 05:14 PM
12/08/17 05:14 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Doesn't matter because i'm starting fresh. So what ever block i need to do what i want.
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415330
12/08/17 05:51 PM
12/08/17 05:51 PM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
Ritter makes an AL. small block that can be configured for just about any available small block head that you want to use. It is pricey though. But It'll take loads of HP.
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415332
12/08/17 05:59 PM
12/08/17 05:59 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Dizuster talked to Rob Goss last year. We were told a stock block with good caps will live at that power level. I believe the stopck forged crank will live as well. If anybody would know it's him. He had a run of blocks done that are good to north of 2000hp.
Doug
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415335
12/08/17 06:04 PM
12/08/17 06:04 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Just brainstorming because I don't have the means or knowledge to build something like this.
For the shortblock you could straight up buy a 6.2 Hellcat shortblock from a dealership, but the powdered metal rods might be an issue at your power levels.
The lighter option would be the 6.1 Aluminum block and whatever combination of rotating assembly is the strongest.
Heads the Thiteks would be the top choice, or the 6.4 BGE heads. Hellcat heads have a different intake pattern and I doubt anyone makes a blower manifold.
No clue about which power adder, looking at the charts on the mopar tech archive http://www.moparts.org/Tech/Archive/bb/57.html a 20% 8-71 hitting around 25psi should be there, but I know there is more to it then that.
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415344
12/08/17 06:28 PM
12/08/17 06:28 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
83mm will make 1300hp with its eyes closed...
Can you run a billet wheel? What other limitations?
Correct a stock 6.4L block with forged rotating assy. should hold up no problem.
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: dizuster] #2415364
12/08/17 07:05 PM
12/08/17 07:05 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Would a third gen make power power than say a 9.2 R3 Block?
I'm thinking big power turbo too but I got a 48 degree block at the ready.
WIZE
In Car:
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: dvw] #2415392
12/08/17 08:23 PM
12/08/17 08:23 PM
PA.
"Little"John
"Little"John
PA.
Doug
I don’t know at what horsepower level Rob started having issues but I know he was sure splitting his share of them apart. If I was starting off with a clean sheet like you are with zero inventory I would jump into the gen 3’s and never look back. R3’s are to rare and the Ritter block have to many unanswered questions if you could get a usable block in a reasonable amount of time. Get the best gen3 block you can afford and build it from there
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415459
12/08/17 10:24 PM
12/08/17 10:24 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
They have a 48Deg Deep skirt version I'm told might go to 2000hp.
At least its a proven item, and pricey
http://www.jegs.com/i/Mopar-Performance/312/P5007905AB/10002/-1
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415467
12/08/17 10:33 PM
12/08/17 10:33 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
A8 block and a good set of W9's would be light! I would say with a cooler and turbo (35+ lbs) of boost you would be into the 2000hp range.
Just think of a Sprint Car Engine with a turbo.
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Biginchmopar] #2415472
12/08/17 10:47 PM
12/08/17 10:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Good luck finding one.. I had one but sold it about 12
years ago.. plus the timing gears and that set up is
even harder to find
wave
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415497
12/08/17 11:25 PM
12/08/17 11:25 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
The newer a8 blocks are not deep skirted, and from what I've found and been told they won't hold up very long at 1300 horse.
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415503
12/08/17 11:29 PM
12/08/17 11:29 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415550
12/09/17 12:59 AM
12/09/17 12:59 AM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
There are a few Ritter Al. blocks around the country going together right now.
Re: Small Block (380ci) turbo/blower 1200-1300hp [Re: Diablo] #2415555
12/09/17 01:10 AM
12/09/17 01:10 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I agree with some other opinions posted, go gen 3 and don't look back. If I thought I could get a reasonable dollar out of my small block stuff I'd sell out and start over with a gen 3.
