bench testing a headlight door motor.. how to? #2415257
12/08/17 03:07 PM
12/08/17 03:07 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
whats the best procedure to test a 70+ hide away motor? i see a ground tab as well as the + and - plug.
ground the tab and power up the plug? i know to not run it to the stop just want to see if it still works.
i can figure it out just though on of you guys would know the proper way
Re: bench testing a headlight door motor.. how to? [Re: chrisf] #2415286
12/08/17 04:27 PM
12/08/17 04:27 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Its a reversing motor.One way is positive and ground the other reverses polarity so ground becomes hot and hot ground.Easy just jumper ground and hot then reverse.Rocky
Chrysler Firepower
Re: bench testing a headlight door motor.. how to? [Re: chrisf] #2415391
12/08/17 08:15 PM
12/08/17 08:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
apply Ground/negitive/- to the ground tab, then apply hot/+/power to either one (but not to both at the same time) of the 2 leads in the 2 prong male/female connector to "forward or reverse" the motor
The headlight motors internals have a mechanical as well as electrical stops, so no need to worry about hitting the stops (power window motors are another story, they rely on the window regulator to stop/bind them, no internal stops)headlight motors need to hit the electrical stop, so that when the dash switch changes position, the other lead in the plug harness now becomes hot/power/+ to reverse direction, plus when the motor hits it stops, it's basically transferring the opposing stop to be ready to receive a "command" power wise from the dash switch, plus it diables the motor electrically so it dosen't short/burn out holding an electrical load
Re: bench testing a headlight door motor.. how to? [Re: chrisf] #2415468
12/08/17 10:35 PM
12/08/17 10:35 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
thanks guys. appreciate the help.
