The white car makes it's new best.. (((Updated)))
#2415248
12/08/17 02:49 PM
12/08/17 02:49 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
New best last night.. still having problems getting enough fuel through this carburetor. The largest jet that I have is a 164. I know it wasn't the right thing to do but changed to a tiny high-speed air bleed. Trying to accommodate the fuel needs of the motor. The carburetor was not designed for the application it's being used. despite afr's in the high 13s and low 14s.. still managed to rip off a pair of low forties. These small block Mopars are amazing
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: The white car makes it's new best
[Re: WHITEDART]
#2415265
12/08/17 03:28 PM
12/08/17 03:28 PM
Posts: 192 GravataĆ, RS, Brazil
360tripleblack77
BADASS CAR!!! Congratulations Shiloh... Small Block Rules!!!
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
[Re: WHITEDART]
#2415267
12/08/17 03:33 PM
12/08/17 03:33 PM
WHITEDART
bean town ....Ca
The ground wire the right side lights fell off..
[Re: WHITEDART]
#2415271
12/08/17 03:40 PM
12/08/17 03:40 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
Is that picture at Barona or the base ball stadium?
[Re: humpty]
#2415321
12/08/17 05:36 PM
12/08/17 05:36 PM
WHITEDART
bean town ....Ca
Not yet that's going to be the winter project.. the only thing I did was put some fresh rubber Outback
[Re: WHITEDART]
#2415369
12/08/17 07:13 PM
12/08/17 07:13 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
New best last night.. still having problems getting enough fuel through this carburetor. The largest jet that I have is a 164. I know it wasn't the right thing to do but changed to a tiny high-speed air bleed. Trying to accommodate the fuel needs of the motor. The carburetor was not designed for the application it's being used. despite afr's in the high 13s and low 14s.. still managed to rip off a pair of low forties. These small block Mopars are amazing Better flowing boosters or main well. Check for restriction behind the jets.
