Cylinder head CC Tools
#2415183
12/08/17 12:54 PM
12/08/17 12:54 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
I am shopping for a Cylinder Head CC Kit and wanted to get your opinions on which ones you use, and which one you would buy if you had to do it again.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Cylinder head CC Tools
[Re: GTSDave]
#2415191
12/08/17 01:03 PM
12/08/17 01:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a home made set up.. the plate is Plexiglas and use a 100 cc burette.. it works fine.. I use to have a nice glass one but it broke.. so its plastic now days
[Re: GTSDave]
#2415203
12/08/17 01:28 PM
12/08/17 01:28 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
My son used tha same as Mikes.He did lots of heads at the HD shop.Hey Mike do any good deer hunting?Youngest got a nice doe.I dont shoot unless its a big buck.Rocky
Chrysler Firepower
[Re: therocks]
#2415210
12/08/17 01:40 PM
12/08/17 01:40 PM
MR_P_BODY
My son used tha same as Mikes.He did lots of heads at the HD shop.Hey Mike do any good deer hunting?Youngest got a nice doe.I dont shoot unless its a big buck.Rocky I got a nice 4 point.. had to pass on a bunch of other deer due to my license(had to be 4 points per side or more) wife didnt get anything this year.. she did see a lot of does but passed
[Re: MR_P_BODY]
#2415214
12/08/17 01:51 PM
12/08/17 01:51 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought this one YEARS ago and love it. It easily packs away for storage. https://www.summitracing.com/parts/sum-911581
[Re: pittsburghracer]
#2415224
12/08/17 02:05 PM
12/08/17 02:05 PM
MR_P_BODY
I found that I dont need the burnett stand.. nice but not needed.. I can hold it.. plus I wont buy another glass one.. on mine the shut off valve broke off so it was trash.. the plastic one has the valve and works great and I can drop it and its fine
[Re: MR_P_BODY]
#2415237
12/08/17 02:25 PM
12/08/17 02:25 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I found that I dont need the burnett stand.. nice but not needed.. I can hold it.. plus I wont buy another glass one.. on mine the shut off valve broke off so it was trash.. the plastic one has the valve and works great and I can drop it and its fine Maybe if you had the stand you wouldn't drop it. LOL. I've never dropped mine, knock on wood.
#2415240
12/08/17 02:32 PM
12/08/17 02:32 PM
MR_P_BODY
I found that I dont need the burnett stand.. nice but not needed.. I can hold it.. plus I wont buy another glass one.. on mine the shut off valve broke off so it was trash.. the plastic one has the valve and works great and I can drop it and its fine Maybe if you had the stand you wouldn't drop it. LOL. I've never dropped mine, knock on wood. It fell over when I bumped it with my elbow while it was sitting on my iron welding table.. I'll take the plastic one any day
[Re: Blucuda413]
#2415264
12/08/17 03:22 PM
12/08/17 03:22 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
On the cheap and easy use a plexiglass plate and a large animal syringe from a farm store. I did that for several sets of heads and then bought a isky 50 CC calibrated plastic tube, no good I finally bought a 100 CC glass burrette like the Summit one with a stand like that from a drug supply vendor in SO CA, that is the way to go in my opinion That is what NHRA was using in tech tear downs also I agree with Mike on the glass plate, a 5 inch square plastic plate is better I put a valve relief slot on one side to do Hemi heads that have been cut and have the edge of the intake valve above the head surface. I drilled a 1/4 inch hole in the middle and ended up filling it and put the filler hole up near one edge so it fill better by tilting the heads up to help fill the chambers I also bought a small hand held grease gun and bought a needle tip to make the grease lay a thin bead around the chamber instead of doing that job by hand IHTHs
[Re: GTSDave]
#2415329
12/08/17 05:50 PM
12/08/17 05:50 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I have the Summit one , I like it , price wasn't bad.
[Re: GTSDave]
#2415336
12/08/17 06:05 PM
12/08/17 06:05 PM
GTSDave
Thanks All,
Lots of good ideas. Didn't thing about plastic v/s glass. Our UPS folks could break an anvil so.... gonna keep that in mind when I pick one.
-Dave
[Re: calrobb2000]
#2415365
12/08/17 07:08 PM
12/08/17 07:08 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
hi any one have one that holds more fluid as hemi heads use 160-180 cc.
i have to always carefully refill it at 100 cc? I use graduated cylinders. They're dirt cheap on ebay and can be had in plastic or glass and just about any volume you want. My Burets are safely stored and never used anymore. You don't really need to carefully fill to 100cc. Just as long as you record starting/ending volumes and can do grade-school math.
[Re: calrobb2000]
#2415367
12/08/17 07:11 PM
12/08/17 07:11 PM
MR_P_BODY
[quote=calrobb2000]hi any one have one that holds more fluid as hemi heads use 160-180 cc. i have to always carefully refill it at 1 You can look in a medical book and see what they have.. I have bought up to a 4000cc one so we could measure out 1 gal accurately when in the fuel lab... probably wont have a stand but check.. we had ones that had a flat bases on them
[Re: GTSDave]
#2415421
12/08/17 09:27 PM
12/08/17 09:27 PM
RapidRobert
Our UPS folks could break an anvil so. X10. I use a Speedway plastic burette (dirt cheap) & drilled a hole about an inch or so (iirc) down from the top & JB welded in a short plastic nipple sideways into the tube then covered half of the top of the tube opening with "half" of a thin round disc so I could tilt it & pour out of the added nipple as opposed to out of the top as is as fluid was going down the outside of the burette. With the plastic plate I needed to drill the access hole slightly bigger & use a HF mini orange funnel held just a hair above the hole as opposed to just setting in there, same thing, fluid wanting to wick up. Have the head tilted just right & hold the funnel with one hand & pour with the other. Add some color to the fluid so it shows on the graduations better & you check the level in the middle as opposed to the sides where it curves up slightly (meniscus iirc, HS chemistry was in the 60's). using only enough fluid to cover how much is needed lets you tilt the burette less for less fluid escapeing but the top half cover/side nipple too care of most of that irritating problem (for a 65 CC head start with 80 CC's). grease the plate perimeter just right so grease doe not get squished into the chamber. On one SB the valve edge stuck past the deck so I cut a groove in the plate where the valve protruded then filled it with vaseline so I'd get a true reading.
