vacuum advance 3438262 #2413851
12/05/17 09:59 PM
12/05/17 09:59 PM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
I need to replace my vacuum advance 3438262 seems to catch on something then lets go inside the pod. Is there an adjustment on this unit? what aftermarket advance would fit ? I see there are a couple of versions..
Re: vacuum advance 3438262 [Re: FC7 cuda] #2413873
12/05/17 10:35 PM
12/05/17 10:35 PM
if you are pumping it up with a hand held vacuum pump it will act like that. Is that the only issue you are seeing/haveing with it? You can plug the can into manifold/eng idling with the line clamped shut then slowly release it & see if it deploys smoothly all the way.
Re: vacuum advance 3438262 [Re: RapidRobert] #2413884
12/05/17 10:56 PM
12/05/17 10:56 PM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
I was using a hand held pump and it sorta skips while still attached. so I removed the breaker plate thought something was binding and found the plate moves fine ..
Re: vacuum advance 3438262 [Re: FC7 cuda] #2413887
12/05/17 10:58 PM
12/05/17 10:58 PM
That's good to hear.
