#2413851 - 12/05/17 06:59 PM vacuum advance 3438262
FC7 cuda Offline
Loc: nj
I need to replace my vacuum advance 3438262 seems to catch on something then lets go inside the pod. Is there an adjustment on this unit? what aftermarket advance would fit ? I see there are a couple of versions..
#2413873 - 12/05/17 07:35 PM Re: vacuum advance 3438262 [Re: FC7 cuda]
Loc: Lincoln Nebraska
if you are pumping it up with a hand held vacuum pump it will act like that. Is that the only issue you are seeing/haveing with it? You can plug the can into manifold/eng idling with the line clamped shut then slowly release it & see if it deploys smoothly all the way.
#2413884 - 12/05/17 07:56 PM Re: vacuum advance 3438262 [Re: RapidRobert]
FC7 cuda Offline
Loc: nj
I was using a hand held pump and it sorta skips while still attached. so I removed the breaker plate thought something was binding and found the plate moves fine ..
#2413887 - 12/05/17 07:58 PM Re: vacuum advance 3438262 [Re: FC7 cuda]
That's good to hear.
25,074 Registered Members
185,643 Topics
69 Cuda 340 value
by RMCHRGR
01/19/18 06:03 PM
01` 3500 4x4 Front Ring and Pinion
by 6bblFLASH
01/19/18 05:02 PM
Electrical good, won't turn over
by Moparmaniacc
01/19/18 04:49 PM
elastomeric bumper recreate
by superbee471
01/19/18 04:37 PM
