Testing RPM Limit : UPDATE Results #2413726
12/05/17 06:45 PM
12/05/17 06:45 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Since the tracks are closed and the weather is summer like still here,I started looking for a/the reason my 440 does`nt like to make power over 5,000 rpm.
Been all thru the fuel demands/AFR stuff,no improvements.
3 different cams.
Checked valve springs,only a couple tho... shop said OK? 112 seat.
Checked exhaust back pressure .5lbs,nothing there.
Different octane fuels nope.
Hood off,nope.
So I`ve been told that the blower cant feed it and thats why it noses over like that.
So I took the blower off and installed a 4bbl. intake. Weiand Team G.
I had it in the attic from a package deal some years back. Man that thing is HUGE in the plenum,sits as high as the blower.
NO,,,, it NOT ideal for my engine but I ain`t buying something just to test.
1st trip. run surprisingly good till about 5,100 just gives up and pops once.
2nd trip 1st gear only DOWNHILL ,held it to the floor. Got to about 5,200 popped once and made it to 5,600.
Should have redlined and blown up.
So evidently the "tested" valve springs are not up to the job.
What are people using on a .509 hyd. cam these days?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Testing RPM Limit [Re: 6bblFLASH] #2413731
12/05/17 06:57 PM
12/05/17 06:57 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Pretty sure I have Comp 911 springs in my old 440 w/ the 509 cam. That thing'll scream to 6300+ rpm easily.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Testing RPM Limit [Re: 6bblFLASH] #2413742
12/05/17 07:10 PM
12/05/17 07:10 PM
A727Tflite Offline
A727Tflite  Offline
Been a while but if I recall- used to set them up at 125 seat/ 300-350 open at .500".
My 6bbl stocker used the same rate back in the day and would run to 6500 without a hiccup.
Re: Testing RPM Limit [Re: 6bblFLASH] #2413745
12/05/17 07:14 PM
12/05/17 07:14 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
are you using the mopar lifters ??? never had luck with those - but spring pressure seems to be a little low at the seat - do you know what the open pressure was?
Re: Testing RPM Limit [Re: DoubleD] #2413750
12/05/17 07:20 PM
12/05/17 07:20 PM
N.E. Ohio
N.E. Ohio
Have Crower "cam saver" lifters in it now. 1 turn of pre-load .020 I think?
Did use mopar lifters on it the 1st time.
Don` t remember open pressures
Re: Testing RPM Limit [Re: 6bblFLASH] #2413754
12/05/17 07:24 PM
12/05/17 07:24 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
to me it seems you are just running out of spring and going into float - hence the pop you are hearing - might be worth checking the open height pressure and installed height
Re: Testing RPM Limit [Re: DoubleD] #2413761
12/05/17 07:32 PM
12/05/17 07:32 PM
N.E. Ohio
N.E. Ohio
I am going to get fresh springs,probably Comp 911`s.
I am going to test the old ones and see whats up.
Good news is that 11.09 with a 5,000 governor looks pretty good now.
i will have to slow the blower down and start over.
3 cams
2 converters
2 carbs.
2 exhaust systems.................LOL
Re: Testing RPM Limit [Re: 6bblFLASH] #2413769
12/05/17 07:39 PM
12/05/17 07:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
112 on the springs sounds a bit low for a hyd
cam.. I ran some MP springs on one of my roller
cams.. the springs were way off for it.. it
would top out just like yours.. the only reason
I didnt hurt anything was that they went into
coil bind before the valves hit.. that was just
like running a rev limiter
wave
Re: Testing RPM Limit [Re: MR_P_BODY] #2413773
12/05/17 07:45 PM
12/05/17 07:45 PM
N.E. Ohio
N.E. Ohio
wave
Mike you suggested checking the springs a couple years ago on this thing.
got lazy and only ck`d a couple.
Should have just got new ones.
See what this winter holds,maybe pull it apart and go thru it and make sure there isn`t more hiding stuff.
The heads are un-ported as is the intake.
Re: Testing RPM Limit [Re: MR_P_BODY] #2413774
12/05/17 07:47 PM
12/05/17 07:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Without knowing what electronic ignition box you have on there I hope you didn’t get your hands on one of the old mopar boxes that had a built in rev limiter in it. I fought that issue back in the 70’s.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Testing RPM Limit [Re: pittsburghracer] #2413777
12/05/17 07:50 PM
12/05/17 07:50 PM
N.E. Ohio
N.E. Ohio
MSD,,,tried 2 different ones,2 coils/distributors,,,1 chrome 1 orange MP box.
Re: Testing RPM Limit [Re: 6bblFLASH] #2413781
12/05/17 07:58 PM
12/05/17 07:58 PM
PA.
"Little"John
"Little"John
PA.
Good deal. That drove me crazy as we didn’t have info available like we do today. What’s funny is it was a 509 cam in a 340
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Testing RPM Limit [Re: 6bblFLASH] #2413782
12/05/17 08:00 PM
12/05/17 08:00 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
If it where me I would go to a hydraulic roller and kill two birds with one stone.
Running an old hydraulic flat tappet cam is going to kill the engine. Just a mater of time. The oils and all the additive you have to run to keep them alive is not good.
Just my thoughts.
Re: Testing RPM Limit [Re: Biginchmopar] #2413826
12/05/17 09:06 PM
12/05/17 09:06 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I could have saved you a bunch of trial and error, buddy!
That blower when I had had ZERO problems pulling my 446" motor to 5600-5800, I usually shifted right at 5500 tho. Cam was a Crower 282/292 (232/242 @.050 if I remember right or a little bigger than a Comp 280) on a 112 in at 107. I ran the old 933 Hemi springs, heck I still got the 906 heads laying around somewhere! something like 130 seat and 310 over the nose, most people run the comp 986's (if i remember the # right) that are like 110 seat and 285 over the nose.
But I don't think running a 108 Lobe spread 509 would be the way I'd go, way too much overlap so your effective boost will be even lower. I know Landy didn't recommend it for the blower, I had one on my shelf. He recommended a Crane split pattern that was just slightly smaller than my Crower but he told me my choice would work great, and it did.
That blower for what it was (to me) was very impresssive, I was able to take a basically stock compression high 12 second 440 bottom end and add 100+ HP with a swap that took less than 1 1/2 hours to do start to finish. this was the late 80's , no truly affordable Heads back then (except maybe the Iron-1's). I only ran an 850 on it, Landy told me when I bought it to put a 950 on it.
The Team G, Gary (RIP 180) used to crack up whenever I talked about That Manifold not being able to fall out of a tree below about 4000 rpm.
The only difference I can think of and it should be unrelated? is that my combo was a 4 speed.
I guess you considered fuel pressure or a restriction? Last time I saw a motor inexplicably laying down it was pick-up corrosion limiting flow....my friend didn't want to believe me until I dropped his tank and showed him.
WIZE
In Car:
Re: Testing RPM Limit [Re: Streetwize] #2413838
12/05/17 09:36 PM
12/05/17 09:36 PM
N.E. Ohio
N.E. Ohio
Hey Bobby.
The .509 I have is 114c/l in at 110.
Ran a 224/234@114
and a 236/241@110
.509 was fastest with iron heads.
Haven't tried every combination with the aluminum heads yet.
Ran an 11.09@120 with the rpm issues.
Can't wait for next spring.
It should be quite a bit faster
Re: Testing RPM Limit [Re: 6bblFLASH] #2413863
12/05/17 10:18 PM
12/05/17 10:18 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
11.09 @ 120 turning only 5100 is testament to the torque your putting to the ground. 500 more RPM and your running 10.70's at least
I was gonna say the wider 114 509 might work good to overcompensate the head restrictions.
I'd start with fuel, do you have a pressure gauge on it? if you feel it laying down it's likely fuel cause with a blower even with dropping boost it should still pull, just at a lower rate of pull but still harder than say a normally aspirated motor.
WIZE
In Car:
Re: Testing RPM Limit [Re: Streetwize] #2413867
12/05/17 10:28 PM
12/05/17 10:28 PM
N.E. Ohio
N.E. Ohio
Yes pressure gauge.
I can jet up and loose MPH.
With the blower on it if you stay in it it can rev past 5,000 but you have to wait for it.
Probably put 50 passes on it at the track so far, a whole lot more on the road.
Shifting over 5,000 really kills the E.T.
Re: Testing RPM Limit [Re: 6bblFLASH] #2413879
12/05/17 10:49 PM
12/05/17 10:49 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Still thinking valve float or fuel flow. Boost doesn't just lay down like a rock it tapers
WIZE
In Car:
Re: Testing RPM Limit [Re: 6bblFLASH] #2413916
12/05/17 11:31 PM
12/05/17 11:31 PM
Try setting the seat pressures at 140 to 170 lbs. with no more than 400 lbs. open on your current broken in camshaft and matching lifters thumbs
On your deal those current low pressures are not seating the valves at the upper RPM, especially the intakes tsk shruggy
Let us know your results afterwards please work grin
Re: Testing RPM Limit [Re: 6bblFLASH] #2415236
12/08/17 02:25 PM
12/08/17 02:25 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Are you SURE on the lifter pre-load? What kind of rockers? How many turns past 0 lash? If you're 1 full turn past 0 lash thats .042 pre load assuming a standard 24 thread per inch adjuster. That could be too much for your setup. I'd try 1/2 turn (.020)
