Looking for nuetral safety wiring diagram for 1972 Demon #2413177
12/04/17 06:20 PM
12/04/17 06:20 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
4 speed. I don't have a service manual and unable to locate anything on line. Thanks for the help.
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: Looking for nuetral safety wiring diagram for 1972 Demon [Re: moparfan] #2413195
12/04/17 07:07 PM
12/04/17 07:07 PM
see if the diagrams at www.mymopar.com have something
Re: Looking for nuetral safety wiring diagram for 1972 Demon [Re: moparfan] #2413214
12/04/17 07:57 PM
12/04/17 07:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you running a clutch pedal switch? If not then just ground the ground terminal on the starter relay or buy a starter relay for a standard trans. It will have a built in ground. If you have a clutch switch then you ground one terminal from the switch and wire the other terminal to the starter relay ground terminal.
Re: Looking for nuetral safety wiring diagram for 1972 Demon [Re: stumpy] #2413234
12/04/17 08:47 PM
12/04/17 08:47 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Its a factory 4 speed car and am putting a 4 speed back in it. When I removed the 4 speed prior I ran a wire from the starter relay thru the switch on the shifter. I assumed it worked with the 4 speed prior but don't know for sure and can't remember what I did so was going to trace wires.
I didn't crawl up under the dash all the way to see if there is a switch on the pedal, I assume there is.
I want to race the car some so I need it to work plus seems like the right thing to do anyway.
2021 T/A 392
2020 Hellcat redeye
Re: Looking for nuetral safety wiring diagram for 1972 Demon [Re: moparfan] #2413237
12/04/17 08:52 PM
12/04/17 08:52 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
I did find it on the link you sent Robert, thanks
2021 T/A 392
2020 Hellcat redeye
Re: Looking for nuetral safety wiring diagram for 1972 Demon [Re: moparfan] #2413305
12/04/17 11:00 PM
12/04/17 11:00 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It's more of a clutch engagement switch rather than a neutral safety switch. It's located off of the clutch pedal.
Re: Looking for nuetral safety wiring diagram for 1972 Demon [Re: Morty426] #2413353
12/05/17 12:44 AM
12/05/17 12:44 AM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Thanks Morty, that's what I assumed, didn't word it very well. clutch has to be in to start car.
2021 T/A 392
2020 Hellcat redeye
