Page 2 of 2 < 1 2
#2401545 - 11/10/17 05:00 PM Re: Relocating leaf springs [Re: 68dodge]
huimerind Offline
Loc: est
Originally Posted By 68dodge
Are traction bars any good if you have them right up to the front leaf spring eye? Trying to get mine to hook better.
Do the front end work first. Do everything you can to make the front end to move as freely as possible.
I tried to video it, sorry for the quality.. but you should get the point, what clutch tried to say..
No shock is going to fix the movement when the arms does not move.
#2401585 - 11/10/17 06:22 PM Re: Relocating leaf springs [Re: huimerind]
clutch Offline
Loc: S.L . MI
That video above says it all up up
#2401586 - 11/10/17 06:25 PM Re: Relocating leaf springs [Re: huimerind]
bboogieart Offline
Loc: Lost and Spaced
WOW that is one heck of a difference.
I have mechanical Aptitude.
I can screw up anything.
#2402078 - 11/11/17 04:45 PM Re: Relocating leaf springs [Re: huimerind]
clutch Offline
Loc: S.L . MI
Looks like you had the same Idea . That setup works great If the track is decent all I have to do is squeak the 295x65x15 drag radials and it hooks great. up
#2403516 - 11/14/17 11:47 AM Re: Relocating leaf springs [Re: clutch]
ric3xrt Offline
Loc: Trumbauersville PA
I use to use the 1st gen Dakota drop spindles and the 14 inch wheel rotors( I think they are 10.5 Dia.
Rear shocks were always relocated to a straight up and down location.
B body rear springs with the front hanger moved back 4 inches.
#2403524 - 11/14/17 11:57 AM Re: Relocating leaf springs [Re: clutch]
ric3xrt Offline
The other thing to do if you have the cash to spend is do a FATMAN conversion for the pre71 trucks, , takes about 150 of the nose of these trucks.
Clutch , love that truck of yours
I'll have my 75 4x2 Ramcharger out next year with a G3 Hemi, pulling the 440 out and slow it down to mid 10s ,
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
#2403791 - 11/14/17 09:24 PM Re: Relocating leaf springs [Re: ric3xrt]
clutch Offline
Loc: S.L . MI
Nice!! what engine and ET were you running in that pic??
#2404603 - 11/16/17 05:23 PM Re: Relocating leaf springs [Re: clutch]
ric3xrt Offline
489 max wedge headed 426, I think that was 10.20ish forget the mph, that was taken in 86.
#2411677 - 12/01/17 03:29 AM Re: Relocating leaf springs [Re: clutch]
79dodge Offline
Loc: Mid-Missouri
Originally Posted By clutch
They had to be flipped so the t2ie rod don't hit the strut bars. 5th avenue spindles steering arms are bolted on. The rack is mounted on a piece of 2"x3"
heavy wall tube with a nut welded to the back mount just like it did on a Dakota. The trick springs and some 90/10 shocks making sure the control arms
move freely will get you a long way.
Clutch,
You never said what the rack is off of. And the 5th av uses the same ball joint size?
#2412903 - 12/03/17 10:37 PM Re: Relocating leaf springs [Re: 79dodge]
clutch Offline
Loc: S.L . MI
Rack is off a first gen Dakota . Had to ream the taper out a little on the spindles an bush the top one because the taper was on the wrong side.
#2418688 - 12/14/17 06:25 PM Re: Relocating leaf springs [Re: clutch]
Webster Offline
Loc: Ontario Canada
Still looks and launches Awesome !!
1988 Dodge Shortbox Stepside
1947 Fargo Pickup (Project Hot Rod)
1946 Fargo Parts Truck
http://norwoodcruisers.com/
#2424288 - 12/27/17 07:08 AM Re: Relocating leaf springs [Re: clutch]
MattW Offline
Loc: Ontario Canada
FMJ spindles ?
Thx
Matt
Edited by MattW (12/27/17 07:11 AM)
#2424967 - 12/28/17 01:58 PM Re: Relocating leaf springs [Re: MattW]
clutch Offline
Loc: S.L . MI
I used the M body spindles because they were so many around.
Page 2 of 2 < 1 2
25,493 Registered Members
193,106 Topics
Chassis stiffening
by Nick Stevanovski
09/24/18 04:17 PM
Interesting WIW 73 RR original owner 400 4 speed
by Moparpete
09/24/18 03:56 PM
6.75 pass
by dafixr
09/24/18 02:42 PM
MOTOR HOME CAR RAMP TRUCK
by A/MP
09/24/18 02:37 PM
