Re: Relocating leaf springs [Re: 68dodge] #2401545
11/10/17 08:00 PM
11/10/17 08:00 PM
est
huimerind Offline
huimerind  Offline
est
Originally Posted By 68dodge
Are traction bars any good if you have them right up to the front leaf spring eye? Trying to get mine to hook better.
Do the front end work first. Do everything you can to make the front end to move as freely as possible.
I tried to video it, sorry for the quality.. but you should get the point, what clutch tried to say..
No shock is going to fix the movement when the arms does not move.
Re: Relocating leaf springs [Re: huimerind] #2401585
11/10/17 09:22 PM
11/10/17 09:22 PM
S.L . MI
clutch Offline OP
clutch  Offline OP
S.L . MI
That video above says it all up up
Re: Relocating leaf springs [Re: huimerind] #2401586
11/10/17 09:25 PM
11/10/17 09:25 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
WOW that is one heck of a difference.
I have mechanical Aptitude.
I can screw up anything.
Re: Relocating leaf springs [Re: huimerind] #2402078
11/11/17 07:45 PM
11/11/17 07:45 PM
S.L . MI
clutch Offline OP
clutch  Offline OP
S.L . MI
Looks like you had the same Idea . That setup works great If the track is decent all I have to do is squeak the 295x65x15 drag radials and it hooks great. up
Re: Relocating leaf springs [Re: clutch] #2403516
11/14/17 02:47 PM
11/14/17 02:47 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I use to use the 1st gen Dakota drop spindles and the 14 inch wheel rotors( I think they are 10.5 Dia.
Rear shocks were always relocated to a straight up and down location.
B body rear springs with the front hanger moved back 4 inches.
Re: Relocating leaf springs [Re: clutch] #2403524
11/14/17 02:57 PM
11/14/17 02:57 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
The other thing to do if you have the cash to spend is do a FATMAN conversion for the pre71 trucks, , takes about 150 of the nose of these trucks.
Clutch , love that truck of yours
I'll have my 75 4x2 Ramcharger out next year with a G3 Hemi, pulling the 440 out and slow it down to mid 10s ,
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Relocating leaf springs [Re: ric3xrt] #2403791
11/15/17 12:24 AM
11/15/17 12:24 AM
S.L . MI
clutch Offline OP
clutch  Offline OP
S.L . MI
Nice!! what engine and ET were you running in that pic??
Re: Relocating leaf springs [Re: clutch] #2404603
11/16/17 08:23 PM
11/16/17 08:23 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
489 max wedge headed 426, I think that was 10.20ish forget the mph, that was taken in 86.
Re: Relocating leaf springs [Re: clutch] #2411677
12/01/17 06:29 AM
12/01/17 06:29 AM
Mid-Missouri
79dodge Offline
79dodge  Offline
Mid-Missouri
Originally Posted By clutch
They had to be flipped so the t2ie rod don't hit the strut bars. 5th avenue spindles steering arms are bolted on. The rack is mounted on a piece of 2"x3"
heavy wall tube with a nut welded to the back mount just like it did on a Dakota. The trick springs and some 90/10 shocks making sure the control arms
move freely will get you a long way.
Clutch,
You never said what the rack is off of. And the 5th av uses the same ball joint size?
Re: Relocating leaf springs [Re: 79dodge] #2412903
12/04/17 01:37 AM
12/04/17 01:37 AM
S.L . MI
clutch Offline OP
clutch  Offline OP
S.L . MI
Rack is off a first gen Dakota . Had to ream the taper out a little on the spindles an bush the top one because the taper was on the wrong side.
Re: Relocating leaf springs [Re: clutch] #2418688
12/14/17 09:25 PM
12/14/17 09:25 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Still looks and launches Awesome !!
Re: Relocating leaf springs [Re: clutch] #2424288
12/27/17 10:08 AM
12/27/17 10:08 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
FMJ spindles ?
Thx
Matt
Re: Relocating leaf springs [Re: MattW] #2424967
12/28/17 04:58 PM
12/28/17 04:58 PM
S.L . MI
clutch Offline OP
clutch  Offline OP
S.L . MI
I used the M body spindles because they were so many around.
Re: Relocating leaf springs [Re: clutch] #2622339
02/16/19 10:31 PM
02/16/19 10:31 PM
est
huimerind Offline
huimerind  Offline
est
Front
