Re: Road Runner Grille & Bezels - Goodmark VS AMD?
[Re: Old_Moparz]
#2415735
12/09/17 02:54 PM
12/09/17 02:54 PM
Posts: 8,869 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Well here's the thing - and this applies to most reproduction stuff - dies for any metal part are not a single unit but multiple dies. There will be one to stamp the initial flat shape from the sheet, another to stamp the basic shape, another to bend flanges, and so on. A minimum of three dies and possibly six or more depending on the complexity. These dies are LARGE and heavy and extremely expensive.
So having said that, its extremely unlikely that there is more than one set of dies in existence for most repro parts. The exception to this rule would be in the case of Sherman's, who has been stamping out mediocre repro parts for decades. But I strongly suspect that both the Goodmark and AMD stuff comes out of the same dies. HOWEVER, the difference is in the gauge of the metal, AMD uses 18ga as was used on original parts and Goodmark uses metal that is 30% thinner. This applies to body panels. Grills are already thin so they're likely one and the same.
So in the case of grills it boils down to the finish. Are they finished (plated and painted) by the same outfit or not? Do they each have a different spec for the shade of argent (it would appear so).
So the bottom line here is that the fit of either should be the same. The only differentiating factor being the finish.
[Re: Old_Moparz]
#2416525
12/10/17 11:50 PM
12/10/17 11:50 PM
Posts: 3,455 Newburgh, NY
Old_Moparz
Newburgh, NY
Thanks for the links, there are some good photos in them. Seems that the color is the only serious issue which I can probably live with. I've repainted a few grilles & bezels on my other cars with incorrect colors that were close enough to still look presentable. If it is too dark for my liking, which I doubt, a light coat of a lighter shade of paint will work. Thanks for the replies.
[Re: 2abodymcodes]
#2417986
12/13/17 04:00 PM
12/13/17 04:00 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
I used AMD grille and headlight doors on my 69 RR. Actually, the whole front end is AMD. This is the only picture I have at my disposal right now. They fit nice and look good to me. Looks good to me and what a nice RR!
[Re: CompSyn]
#2418499
12/14/17 03:05 PM
12/14/17 03:05 PM
Old_Moparz
Newburgh, NY
I used AMD grille and headlight doors on my 69 RR. Actually, the whole front end is AMD. This is the only picture I have at my disposal right now. They fit nice and look good to me. Looks good to me and what a nice RR! Yes, the car does look really nice. Thanks for the input.
