Where to find a 10" tubular fuel sending unit #2411988
12/01/17 09:58 PM
12/01/17 09:58 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Been seachin with no luck. Does anyone know where to purchase a 10" sending unit. Cell is 10" deep and need a sending unit that reaches the bottom. All i have found is 8" and 12" . doesnt anyone make a 10?
Re: Where to find a 10" tubular fuel sending unit [Re: mopar dave] #2411993
12/01/17 10:06 PM
12/01/17 10:06 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
My understanding is that you can cut the 12" to length. Is the one you found adjustable at the sending unit? Mine is.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Where to find a 10" tubular fuel sending unit [Re: mopar dave] #2411995
12/01/17 10:11 PM
12/01/17 10:11 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Give isspro a call.
Re: Where to find a 10" tubular fuel sending unit [Re: amxautox] #2412000
12/01/17 10:25 PM
12/01/17 10:25 PM
Mt Morris Michigan
Mt Morris Michigan
I currently have an 8 in the cell. Doesnt look adjustable.
Re: Where to find a 10" tubular fuel sending unit [Re: rickraw] #2412001
12/01/17 10:26 PM
12/01/17 10:26 PM
Mt Morris Michigan
Mt Morris Michigan
Ill check that out.
Re: Where to find a 10" tubular fuel sending unit [Re: rickraw] #2412010
12/01/17 11:07 PM
12/01/17 11:07 PM
Mt Morris Michigan
Mt Morris Michigan
Isspro has them. Thanks
Re: Where to find a 10" tubular fuel sending unit [Re: mopar dave] #2412021
12/01/17 11:32 PM
12/01/17 11:32 PM
amxautox Offline
amxautox  Offline
Mine has a screw on the top that adjusts it electronically.
Tom
author unknown
Re: Where to find a 10" tubular fuel sending unit [Re: mopar dave] #2412030
12/01/17 11:55 PM
12/01/17 11:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why dont you cut it to the length you need then
just move the card.. its simple and cheap
wave
Re: Where to find a 10" tubular fuel sending unit [Re: MR_P_BODY] #2412043
12/02/17 12:39 AM
12/02/17 12:39 AM
Mt Morris Michigan
Mt Morris Michigan
Not sure i understand. Mine is 8" and too short. If i slide the card down the float would not be able to slide to the end without falling out of the tube. The 10" is only $58 and an easy swap.
Re: Where to find a 10" tubular fuel sending unit [Re: mopar dave] #2412048
12/02/17 01:00 AM
12/02/17 01:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If the 10" will fit then use it
EDIT
I was thinking you had a 12" and needed a 10"..
its just tubing.. right.. with the card on it..
I assume this is 1/2" tubing
wave
Re: Where to find a 10" tubular fuel sending unit [Re: MR_P_BODY] #2412056
12/02/17 01:16 AM
12/02/17 01:16 AM
Mt Morris Michigan
Mt Morris Michigan
I think so Mike. Buying the 10" is the best way.
