W2 Rocker arms #2411074
11/30/17 12:56 AM
11/30/17 12:56 AM
ohio
2
2264PLY Offline OP
2264PLY  Offline OP
ohio
Is there a difference in the rocker arms for the long valve W2 Econo and the standard length W2 Econo?
Re: W2 Rocker arms [Re: 2264PLY] #2411078
11/30/17 12:59 AM
11/30/17 12:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
SAME arms.. the long valve will sit higher vs
the standard.. I have both type heads
EDIT
The rockers are the same but the valve length
is different.. for the W-2/W-5 use the same
arms
EDIT
there is 2 different off sets to the TD ones
.700 and a .625 offset
wave
Re: W2 Rocker arms [Re: 2264PLY] #2411080
11/30/17 01:19 AM
11/30/17 01:19 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tell us what version/casting of the w2 head you have?
Tony
70 AARCuda Vitamin C
Re: W2 Rocker arms [Re: 70AARcuda] #2411084
11/30/17 01:32 AM
11/30/17 01:32 AM
ohio
2
2264PLY Offline OP
2264PLY  Offline OP
ohio
I have the long valve econo Part#P4529995
Re: W2 Rocker arms [Re: 2264PLY] #2411088
11/30/17 01:38 AM
11/30/17 01:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Do your heads have the blue plugs at each end
wave
Re: W2 Rocker arms [Re: MR_P_BODY] #2411090
11/30/17 01:40 AM
11/30/17 01:40 AM
ohio
2
2264PLY Offline OP
2264PLY  Offline OP
ohio
I don't believe so.They are still in the box.Freeze plugs? Are the valves still readily available?
Re: W2 Rocker arms [Re: 2264PLY] #2411091
11/30/17 01:46 AM
11/30/17 01:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The newer style has blue plugs that are used
after the casting is done.. they did it that
way to get a better casting inside... but the
rockers are the same.. are yours ported yet
wave
Re: W2 Rocker arms [Re: MR_P_BODY] #2411092
11/30/17 01:49 AM
11/30/17 01:49 AM
ohio
2
2264PLY Offline OP
2264PLY  Offline OP
ohio
Brand new untouched castings.Are the valves readily available?Not brand new I've had them for quite awhile. They are probably the older castings.
Re: W2 Rocker arms [Re: MR_P_BODY] #2411095
11/30/17 01:54 AM
11/30/17 01:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What size valves will you be running... you
can get a 2.02/ 2.05 or the 2.08 in it but
stock version was a 2.02.. also you might
want to go with the smaller dia stems.. they
help flow... yes the valves are available
wave
Re: W2 Rocker arms [Re: 2264PLY] #2411097
11/30/17 01:56 AM
11/30/17 01:56 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
w5 had blue plugs on the end...W2 some had freeze plugs on the end..
Tony
Re: W2 Rocker arms [Re: 2264PLY] #2411100
11/30/17 02:01 AM
11/30/17 02:01 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
https://books.google.com/books?id=S7rgkZ...995&f=false
read the blue box Econo Head,,,,tells you what length valves are needed...
Harland Sharpe sells rockers for the econ head.w2...1.5 or 1.6 ratio.
the MP or Crane w2 rocker are no longer made by Crane...Ductile Irons ones are no longer made...Both can be found on Ebay at times..last time I searched ebay there were a couple aluminum ones for sale.
Tony
Re: W2 Rocker arms [Re: 70AARcuda] #2411106
11/30/17 02:11 AM
11/30/17 02:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Right... thats what I'm working on now
wave
Re: W2 Rocker arms [Re: 70AARcuda] #2411127
11/30/17 03:15 AM
11/30/17 03:15 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
And not all W5 heads had the blue plugs. Just later castings did
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: W2 Rocker arms [Re: 2264PLY] #2411537
11/30/17 11:29 PM
11/30/17 11:29 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I know that...someone was making a reference to w2 having the blue plugs...which they never did
Tony
Re: W2 Rocker arms [Re: 2264PLY] #2411708
12/01/17 10:51 AM
12/01/17 10:51 AM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Si, Manley, Ferrera and others make valves... x2 for the smaller stem valves.
Depending on your use you can get hollow stems for better valve control at higher rpm's. I have the same heads and wish I could afford to swap out those 3/8 valves...
Re: W2 Rocker arms [Re: Medlock51] #2411782
12/01/17 02:45 PM
12/01/17 02:45 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Valves can be sourced anywhere as mentioned.Almost everything these days is just a SBC valve, or some derivative of one. You can typically make an easy swap out to 11/32 because a guide liner can be used, and its close on size to the 3/8" bore currently. You can also go with full bronze guides if you think thats what you want, albeit more costly.Reducing some area of the valve stem, and reducing valve weights are both good efforts. Dwayne could answer of the top of his head I'm sure, but I have flow comparisons on W2's at the shop, along with RHS/Indy and Enginequest, showing 3/8 vs 11/32 valves. Some arent as big as an advantage as you would think, but I'll take the lighter weight anyday.
RIP Monte Smith
Re: W2 Rocker arms [Re: 2264PLY] #2412046
12/02/17 12:51 AM
12/02/17 12:51 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
@2264PLY The valve question is precisely what I had spent some time on, but finally found a valve that is nearly the matching length.
Take a look at the following Manley valves:
1) INTAKE - Manley, 11702-8, Severe Duty Pro-Flo
2) EXHAUST - Manely, 11703-8, Race-Flo
The only challenge here is that these are 11/32 stem diameter. Like you, I have the W2 long valve heads sitting in their original boxes here...not exactly keen on spending the extra $$$ on re-working the heads, but I figured I'd do it right the first time around.
Nothing wrong with the 3/8 stem valves, but if I'm going to spend money on something I might as well aim to save a little weight, thus the move to the 11/32 stem.
Ahh, one other thing, the Manely intake valve is under-cut as well, so apparently a tad better flow at lower lifts - no 1st hand experience here, just a quote/un-quote from their catalog.
Re: W2 Rocker arms [Re: Diplomat360] #2412055
12/02/17 01:16 AM
12/02/17 01:16 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
The W2's with 3/8 (2.02 valves) will easily flow over 300 with porting work so decide how much performance you need from there. I was extremely happy I didn't spend the extra money to upgrade my valves after my W2's cracked. They are now "leaners" along my garage shop wall.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: W2 Rocker arms [Re: 2264PLY] #2412162
12/02/17 11:24 AM
12/02/17 11:24 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The W2s on my 416 flow in the 320s with 2.02 3/8 stem valves. I believe they are MP valves.
68 Barracuda Formula S 340
Re: W2 Rocker arms [Re: 2264PLY] #2412173
12/02/17 12:03 PM
12/02/17 12:03 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Si will build valves in any size or length you need at very competitive prices.
www.sivalves.com
CWE is correct... liners work very well and are cost effective. Many builders are using them instead of replacing existing bronze guides.
