A518 floor pan mods - 69 charger ?? #2408658
11/25/17 02:06 PM
11/25/17 02:06 PM
moparx Offline OP
moparx  Offline OP
what floor pan mods are needed to install an A518 behind a big block in a 69 charger ? i know this has been discussed before, but i was unable to find what i need using the search, and google custom search. unless i missed something.......
as usual TIA. bow
beer
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2408720
11/25/17 04:57 PM
11/25/17 04:57 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You would think that this would be common knowledge by now but so many of us Mopar guys are 20 years or more behind the curve. GM guys have been putting the 200-4R and 700-R4 in classics since the late 80s.
The 518 requires removal of the center section of the torsion bar crossmember. If you plan to retain a torsion bar suspension, you'd need to fabricate a replacement center section with a taller arch in it. Also, there is a few reinforcing ribs in the tail shaft extension housing that can be cut away to obtain clearance. It has been documented at DodgeCharger.com but their search feature is not real helpful. Check their Engine, Transmission and Driveline forum.
Re: A518 floor pan mods - 69 charger ?? [Re: Kern Dog] #2408832
11/25/17 10:28 PM
11/25/17 10:28 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Is the floor and crossmember that different in a 69 B from my 70 Cuda? I put a 518 in my Cuda last year and didn't have to hack the thing up.
Trimmed the tailshaft some and had to dimple the floor pan. It is certainly tight in a couple of places, but workable.
Master, again and still
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2408836
11/25/17 10:35 PM
11/25/17 10:35 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I think the engine sits slightly forward more in the E body cars, making the transmission tunnel a little more forgiving.
Re: A518 floor pan mods - 69 charger ?? [Re: Kern Dog] #2408839
11/25/17 10:38 PM
11/25/17 10:38 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Have you done one ?? you have to trim the T bar X member, not cut out the arch & raise it, you just have to thin that area & weld it back.
After that there is a few spots that have to be hammered up for room.
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2408957
11/26/17 01:38 AM
11/26/17 01:38 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Well no offense to you, but you also have spacers between the frame rails and K member. That is something that I would never do. The tapered shank of the K member bolts were designed to positively center the K member to the car structure. Given that you did this, I also suspect that you may have installed the transmission lower than others might. This would result in less transmission tunnel mods.
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2409000
11/26/17 03:20 AM
11/26/17 03:20 AM
IMGTX Offline
IMGTX  Offline
I posted lots of pics of a 518 in an e-body mod in this thread.
https://board.moparts.org/ubbthreads/ubbt...-automatic.html
It should be the same on an 69 B body. With Torsion bars, floor pans, K-frames, suspension and even the rear mount brackets swap-able (or at least nearly swap-able in some cases) between mid 60 to 72 B body and 70-74 Ebody I think it would work. I KNOW THERE ARE DIFFERENCES IN THE PARTS ALONG THOSE YEARS BUT THEY WILL BOLT IN PLACE SO THE STRUCTURE CAN'T BE MUCH DIFFERENT.
Instead of removing the center of the brace I just trimmed the stiffening ribs and some unnecessary mounts of the side of the transmission.
Worked fine for me. Just food for thought.
Re: A518 floor pan mods - 69 charger ?? [Re: Kern Dog] #2409028
11/26/17 10:27 AM
11/26/17 10:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Spacing a K frame is no big deal. Almost any new cars (which are uni-body) have a cradle with oversize holes that can be shifted fore/aft, left/right. Once the bolts are torqued its not going any where.
CSK, Nice article on the Charger.
Doug
Re: A518 floor pan mods - 69 charger ?? [Re: dvw] #2409055
11/26/17 12:13 PM
11/26/17 12:13 PM
moparx Offline OP
moparx  Offline OP
can a factory console shifter be used ? what mods need done to it ?
beer
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2409094
11/26/17 01:46 PM
11/26/17 01:46 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
My Cuda is floor shift. The linkage is tight, but works fine with only a couple of tweeks.
As to the discussion on lowering the K. I have done it on numerous cars with no issue. And didn't Mopar do it on the 68 SS cars? Seems that it worked okay there, too.
twocents
Re: A518 floor pan mods - 69 charger ?? [Re: dvw] #2409130
11/26/17 03:00 PM
11/26/17 03:00 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Doug
Thank You smile
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2409131
11/26/17 03:01 PM
11/26/17 03:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
beer
I have seen the factory linkage works, but I converted my factory shifter to a cable.
Re: A518 floor pan mods - 69 charger ?? [Re: Kern Dog] #2409133
11/26/17 03:04 PM
11/26/17 03:04 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I'll ask again, have you done one ? I thought you were smart, NEVER SAY NEVER , LMBO. NO my trans is not lower than others, if anything it is higher.
this picture is before I shimmed the K frame
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2409167
11/26/17 04:39 PM
11/26/17 04:39 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Have I performed this swap?
No I have not. I do READ though. I installed a Gear Vendors OD and there was a variance of advice on that installation. As with other topics, there is often dissention on the correct way to do things.
Re: A518 floor pan mods - 69 charger ?? [Re: Kern Dog] #2409172
11/26/17 04:46 PM
11/26/17 04:46 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
so you are saying I did not do it correct. LOL smile
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2409408
11/27/17 12:27 AM
11/27/17 12:27 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
No, I was just thinking that your situation is a bit different. The K member spacers and dropped transmission mount probably resulted in less of a need to notch the torsion bar crossmember.
We all have deviations from stock that we are comfortable with or NOT willing to do.
Some guys seemed to wig out when I wrote that I had 12 year old tires on my car that I drove 100 mph for short blasts. The tires looked nearly new. When I replaced them, they even looked great from the inside. If you ask the "Tire experts", they swear that a car with tires older than 6 years is a a huge risk.
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2409463
11/27/17 02:13 AM
11/27/17 02:13 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've not done this swap on a 69 Charger, but I have played with enough Mopars of this era to know Chrysler quality control, as far as body tolerance are concerned, was pretty loose.
I suspect what actually will need to be done will be car specific. You can line up 10 different 69 chargers (or any other Mopar car line) side by side, and the modifications required to perform the same task will probably be different between more then 1/2 of them. The differences can range between very easy and very difficult, or be anywhere in between.
Posted in this thread may be both extreams, Moperx won't know what will actually needs to be done until he gets started. Gene
Re: A518 floor pan mods - 69 charger ?? [Re: poorboy] #2409537
11/27/17 12:17 PM
11/27/17 12:17 PM
moparx Offline OP
moparx  Offline OP
you are spot on as usual gene. i really won't know exactly what will need done until i start. just looking for general guidance now, and other's experience. as you said, the QC of these cars is/was all over the place when new, then add age and [possible] crash damage to the mix, who really knows what a particular car will actually require. luckily, i can fabricate and weld !
beer
Re: A518 floor pan mods - 69 charger ?? [Re: CSK] #2409765
11/27/17 08:23 PM
11/27/17 08:23 PM
IMGTX Offline
IMGTX  Offline
On the mod you did.
Did you trim anything on the transmission or just thin out the Torsion bar crossmember?
Re: A518 floor pan mods - 69 charger ?? [Re: moparx] #2409821
11/27/17 10:02 PM
11/27/17 10:02 PM
BDW Online content
BDW  Online Content
Definitely need to trim
