Re: 727 Overheating
[Re: moparonly]
#2408960
11/26/17 01:41 AM
11/26/17 01:41 AM
Posts: 21,477 It's a dry heat
gtx6970
It's a dry heat
So what is preventing fluid from being pumped to the cooler and making the trans overheat? Could the trans still run rock solid with a bad pump? I’m at a loss.
Short answer, NO. No pump pressure = no gears Put a pressure gauge on the line port. my money it goes sky high pressure wise If the trans is hot (and works) and the lines are cold theres a blockage
Re: 727 Overheating
[Re: moparonly]
#2409090
11/26/17 01:37 PM
11/26/17 01:37 PM
gtx6970
It's a dry heat
That's what I thought because an automatic transmission is basically a hydraulic pump but I just wanted to make sure I wasn't missing something.
Just to make sure we're on the same page, you're saying remove the cooler line from the front port and screw a gauge directly into the port, right? No, the line pressure test port is on pass side. Pressure should be 'about' 75 psi at idle , and should rise as the kick down lever is moved rearward. But looking at your fluid condition. I would say a rebuild is in its very near future. Looks like metal indicating hard part failure internally
Re: 727 Overheating
[Re: dvw]
#2409174
11/26/17 04:47 PM
11/26/17 04:47 PM
Posts: 27 West Valley City, UT
moparonly
Where did you check the cooler flow? The front port exits the trans directly from the converter. The rear line is the return into the trans. No fluid at the rear line could be a plugged cooler or line. No fluid out the front port of the trans after swapping valve body's is puzzling. The only thing I can think of is a restriction in the pump discharge passage. Doug I blew compressed air directly into the outlet port where fluid is directed from the valve body to the cooler. I even blew compressed air in the feed and return hole for the torque converter. I'm about to go out and do a few tests so I'll keep you guys posted. I'm glad I'm not the only one puzzled by this. I've been studying my Carl Munroe handbook for a while now trying to figure this out.
Re: 727 Overheating
[Re: screamindriver]
#2409406
11/27/17 12:23 AM
11/27/17 12:23 AM
Posts: 20,204 Park Forest, IL
slantzilla
Park Forest, IL
Let's hope you didn't fry the clutches...The fluid isn't looking good there... Something has ground itself to get that color...I'm glad you've found the problem but it might not be over... Whatever ate itself could be wjat plugged the cooler too.
Re: 727 Overheating
#2409484
11/27/17 03:16 AM
11/27/17 03:16 AM
moparonly
Let's hope you didn't fry the clutches...The fluid isn't looking good there... Something has ground itself to get that color...I'm glad you've found the problem but it might not be over... Yeah I'm sure this is just the beginning of more chain of events. The fresh fluid I put in didn't look much better when I got it pumping out. Something got fried in there and it's only a short matter of time until it'll need a rebuild. I'm hoping the clutches took the brunt of it and not any steel parts.
