Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408634
11/25/17 01:16 PM
11/25/17 01:16 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Yeah, and everybody knows there isn't an A-Body on the planet as Sexy as an E-Body. Thats just how it is.
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408652
11/25/17 01:57 PM
11/25/17 01:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My 73 Cuda only weighed 2130, of course the whole body was fiberglass.LOL
An E-body is only 4-5 inches wider and maybe a little shorter than an A-body, can't see 300 lbs difference both cars being equal with the same weight removed( fenders,doors,trunk). Now full car as built, could be.
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408665
11/25/17 02:20 PM
11/25/17 02:20 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By 590 Challenger
but she's so sexy! And after having it for 34 years my wife would kill me. However I could picture myself throwing this combo in a little Daytona
"590 crapbox Daytona" doesn't have the same ring to it and you would have to call it that to differentiate from the REAL Daytonas. hammer
'63 Dodge 330
11.19 @ 121 mph
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408672
11/25/17 02:36 PM
11/25/17 02:36 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Drum brake spindles are lighter but would need a different caliper adapter.
Re: Does Anyone Make Light Weight E body Spindles? [Re: GY3] #2408693
11/25/17 03:37 PM
11/25/17 03:37 PM
Parts unknown
590 Challenger Offline OP
Parts unknown
Yeah but I'm getting really tired of starring at the back end of those little mustangs
Re: Does Anyone Make Light Weight E body Spindles? [Re: @#$%&*!] #2408695
11/25/17 03:38 PM
11/25/17 03:38 PM
Parts unknown
Parts unknown
Thanks, that is what I have now, I will touch them up with a tad of grinder love
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408715
11/25/17 04:34 PM
11/25/17 04:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Grind on them, radius the corners, then shot peen them to harden the surface.
Magnaflux for cracks first.
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408727
11/25/17 05:15 PM
11/25/17 05:15 PM
STEFF Offline
STEFF  Offline
Your glass bumpers chromed?
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408734
11/25/17 05:39 PM
11/25/17 05:39 PM
Parts unknown
Parts unknown
Bumpers are still the original ones, mounted to aluminium tubes, I guess its time for a change
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408755
11/25/17 07:17 PM
11/25/17 07:17 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My Duster could handle all that power. Car was over built for what I use it for. ...And its for sale. Weighs 2700ish without me. Still has steel fenders and doors with roll up windows.
Re: Does Anyone Make Light Weight E body Spindles? [Re: Dragula] #2408775
11/25/17 08:00 PM
11/25/17 08:00 PM
Parts unknown
Parts unknown
Thanks but I just think I will try to shave a few pounds this winter. I'm also cutting the engine down to a 528, adding aluminum rods, raising the compression, uping it from 30 to 45 pounds of boost, hoping to stuff it into the lower half of the 4's next season. Time will tell
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408819
11/25/17 10:04 PM
11/25/17 10:04 PM
New York
polyspheric Offline
polyspheric  Offline
New York
In the picture, the bolt attachment points are entirely in shear and can have much less material around them, grind off the excess.
The arch going to the ball joint is more dangerous.
Boffin Emeritus
Re: Does Anyone Make Light Weight E body Spindles? [Re: polyspheric] #2408883
11/25/17 11:23 PM
11/25/17 11:23 PM
Parts unknown
Parts unknown
Kool, I won't get too carried away
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408899
11/25/17 11:44 PM
11/25/17 11:44 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Do you run plastic headlights?
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408917
11/26/17 12:29 AM
11/26/17 12:29 AM
Parts unknown
Parts unknown
I never even heard of them
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2408934
11/26/17 12:53 AM
11/26/17 12:53 AM
New York
polyspheric Offline
polyspheric  Offline
New York
That metal is also unsprung weight (same as wheel and rotor), extra benefit to lightness, helps tire grip.
Boffin Emeritus
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2409057
11/26/17 12:23 PM
11/26/17 12:23 PM
Winston-Salem, NC
JackZ Offline
JackZ  Offline
Winston-Salem, NC
Have you looked at using spindles from an old A body that had 9" drum brakes?
Re: Does Anyone Make Light Weight E body Spindles? [Re: 590 Challenger] #2409972
11/28/17 02:33 AM
11/28/17 02:33 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Carbon fiber ceramic rotors= 10 lbs per rotor less
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
