67 Coronet R/T 14 x 5.5 wheel
#240852
03/02/09 01:08 PM
03/02/09 01:08 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
I am having a heck of a time locating an example of the correct steel wheels for my 67 R/T convert. Does anyone out there have a picture of one so I at least know what to look for. I have never seen one and have told about ten different conflicting things about them. Thanks in advance for the help.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
Re: 67 Coronet R/T 14 x 5.5 wheel
[Re: ScottSmith_Harms]
#240854
03/02/09 09:02 PM
03/02/09 09:02 PM
Posts: 2,601 Great White North
Furyman
Great White North
I have about 100 early (big dog dish) rims out being shot blasted....can probably put a couple of date coded sets together.I'm first in line for my own WS27L77 ride though.
"Long Live Mopars"
#240862
03/05/09 12:27 PM
03/05/09 12:27 PM
sixpackbee
Western New York
Scott, When I dug through the 67 parts book I found two numbers for the 5.5" wheels. One listed as deep dish. Is it safe to assume that is the "Hemi" wheel you have? The more I find out the more a nice new set of Magnum 500's look. Even though it is known to have come with hub caps.
#240864
03/05/09 12:51 PM
03/05/09 12:51 PM
Posts: 1,304 Northern Indiana
mr_belvedere
super gas
super gas
Northern Indiana
I have two sets for reference, one set is date coded (spring of 1967). The other set is off of an earlier car and does not have dates (most don't have dates). They are all 14 x 5.5" and all have a small "5" stamped on both sides of the valve stem. These are much harder to find than most people think.
Scott, are you saying that most lack a date code anywhere on the wheel, or just on the face in the raised lug nut area?
#240865
03/05/09 12:56 PM
03/05/09 12:56 PM
mr_belvedere
super gas
super gas
Northern Indiana
Ignore the parts book in this case, it will just add confusion.
The black wheel and the yellow wheels shown above are indeed 100% correct original 67 Hemi wheels.
These same one year only rims came on a few other 67 cars as well (440 GTX's and R/T's, and SOME station wagons for example).
NEVER ignore station wagons in a salvage yard, I scored one (that was all that was on the '67 coronet wagon) of these wheels for 5 dollars once.
[Re: mr_belvedere]
#240866
03/05/09 01:54 PM
03/05/09 01:54 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I have found that dated wheels are dated on the lug nut/wheel center face as well as on the rim next to the valve stem, but not on the inner wheel surface normally hidden being covered by the tire as in other/later wheels, in fact, they are completely unmarked inside, nothing stamped into them at all. These dated wheels have the 5.5 stamped seperately adjacent to the date stampings as opposed to non dated wheels that have the 5 on either side of the valve stem. Often times the wheel centers are stamped at a different time than the outer rim before being welded together so the center could be an earlier stamping date and the rim will be the date the wheel was actually assembled, usually only by a day or so if different.
Undated wheels don't have a recognizable date stamped anywhere on the wheel.
#240867
03/05/09 09:13 PM
03/05/09 09:13 PM
Furyman
Great White North
The white rim is off a customers WL21J71 car..low mileage should be original.Maybe more than one vendor for the 67 rim??My 67 Canuk parts book lists 3 different part # 14 x 5.5's for RW. 2530330 2122499 2534702 which is listed as Charger Deep Dish
I got the first load of 100 rims back from the shotblaster yesterday and we epoxy primed them today.If I get some time I'll start sorting tomorrow.Going to have to make a rim rack i guess.The shot blasting does a real nice job...all the stampings are real clear.I think I'll do my entire stock of used steelies over the next month.
"Long Live Mopars"
[Re: Furyman]
#240868
03/05/09 09:46 PM
03/05/09 09:46 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
That white rim may be the real thing, I couldn't say without a closer look, but it sure APPEARS to be like the blue one I posted. If the original 67 hub cap won't fit it, it's guilty! Quote:
None of those numbers will help you much since none are stamped on the wheels. As far as being more than one vendor or part #, sure, it's possible, but one things certain, they all had a 5.5 stamping, and they were all the same shape and configuration, if you find something otherwise I'll be greatly surprised, I've been chasing these wheels for over 20 years, I've seen a large number of originals and they simply don't vary much.
#240869
03/05/09 10:36 PM
03/05/09 10:36 PM
Furyman
Great White North
mistake ! I just looked at the parts book again and the 2530330 is the B Body 14 x 5 rim...which I think is wheel code # 13 on the broadcast sheet. Wheel # 2534702...the Charger deepdish is Wheel # 16 on the broadcast...in my small selection of bc sheets not used on any B Body except Chargers.But it is used on a ton (or two )of 67 C bodies ! That would leave wheel # 2122499 as the RW 14 x 5.5 rim.Kinda weird to have that early of a part # used don't ya think ?
"Long Live Mopars"
