70 Stepside & Big Block #2405924
11/19/17 02:30 PM
11/19/17 02:30 PM
Surface of the Sun, AZ
Hotwheelsjr Offline OP
Anyone done this? Dropping a 383 in a 70 Stepside...what motor mounts do I need to use and anything else I need to be aware of?
Re: 70 Stepside & Big Block [Re: Hotwheelsjr] #2405933
11/19/17 02:58 PM
11/19/17 02:58 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
My 68 D100 is an orig 383 BB truck, so no issues there when installing a new 383 Magnum other than some mods to the mounts so the shorty headers would fit. On my 71 W100, we modified some used BB mounts to fit the 70 383 Magnum. Schumacher sells conversion mounts for your truck, but says they're out of stock. I'd call him and see when & if he's making a new batch soon.
http://engine-swaps.com/Pages/ProductsYear/66.87BRBtruck.html
Re: 70 Stepside & Big Block [Re: Hotwheelsjr] #2405953
11/19/17 03:32 PM
11/19/17 03:32 PM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
I have a pair of mounts from a motorhome that you can have if they can work for you. They are similar to the 71 & older 2wd mounts. LMK
Re: 70 Stepside & Big Block [Re: Hotwheelsjr] #2406317
11/20/17 01:23 PM
11/20/17 01:23 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Here are the 71-down BB mounts.
I might have a pair, i'll check.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 70 Stepside & Big Block [Re: Hotwheelsjr] #2407009
11/21/17 08:48 PM
11/21/17 08:48 PM
moparmarks Offline
moparmarks  Offline
PM sent.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 70 Stepside & Big Block [Re: moparmarks] #2407169
11/22/17 01:17 AM
11/22/17 01:17 AM
Originally Posted By moparmarks
PM sent.
Thanks Marc! And thanks Mark! up
Re: 70 Stepside & Big Block [Re: Hotwheelsjr] #2408216
11/24/17 01:22 PM
11/24/17 01:22 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I had a 70 D200 many moons ago. It was a factory 383 truck, and I remember it having a front sump oil pan. There was a mile of room between the pan and axle, so I don't know if it would be an absolute necessity or not? Gerst Suspension had a nice conversion setup for those trucks at The Nats this year. If you're looking to lower it and have a modern PS rack.....it might be worth a look. scope
Re: 70 Stepside & Big Block [Re: JDMopar] #2409192
11/26/17 05:28 PM
11/26/17 05:28 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Thanks for that Gerst info.
