Back spacing on 15x8 rim for 69’ Dart #2408023
11/23/17 09:23 PM
11/23/17 09:23 PM
British Columbia, Canada
3
340Forrest Offline OP
Looking at buying a set of centerline wheels for my 1969 dart swinger 340 4 speed and I’ve been having troubles finding a set since I guess the don’t make them anymore? Found a used set local, they’re 14x6 with 3 3/4 back spacing roughly and 15x8 with 3 3/4 back spacing roughly.... will they fit on my car? I was told 4 7/8 for the rear but just want to confirm this.... the car is completely stock....
Re: Back spacing on 15x8 rim for 69’ Dart [Re: 340Forrest] #2408028
11/23/17 09:41 PM
11/23/17 09:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Is it still small bolt pattern factory axles?
If so 4.5" backspacing will work. But you might fit a 245/60/15. But 235/60/15 is more realistic cause the 8" wide rim takes the tire bulged outward. And a 235/60/15 on a 15x7 with 4.25" backspacing is a safer bet.
On my 68 Dart, I have 245/60/15 on 15x7 4.25" backspacing on a factory stock small bolt axle 8.75. It barely rubs on inside and out. Has worn leaf bushings.
Re: Back spacing on 15x8 rim for 69’ Dart [Re: 340Forrest] #2408035
11/23/17 10:06 PM
11/23/17 10:06 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
^^ depending on bolt pattern 4.5 to 5 inches. Five is the closest I can get without touching the spring (1/4 ") on my Duster, it has the same inside measurement as the Dart, just outside fender is different. Like guy above said 4 inch pattern is 1/4 " shorter than the 4-1/2 pattern, you can use spacers to move out a little. Watch the front edge, to tall a tire will hit.
Re: Back spacing on 15x8 rim for 69’ Dart [Re: 340Forrest] #2408113
11/24/17 01:16 AM
11/24/17 01:16 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I put stock 15x8 warlock(lil red) rims on my 69 dart with re-drilled to 4.5" bp stock axles and the springs not moved in. Do not recall tire size, but the rim itself fit pretty well.
