1200-1500hp - World iron hemi block? #2407949
11/23/17 06:14 PM
11/23/17 06:14 PM
Superfreak OP
Superfreak OP
14-71 roots blower, GRP aluminum rods, Stage V custom heads 7000rpm max. Think it will hold together? I would probably need max hp at 1300. Car is built for 8.5 so......... and no desire to go faster.
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407950
11/23/17 06:16 PM
11/23/17 06:16 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I’ll gladly test it for you.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407955
11/23/17 06:25 PM
11/23/17 06:25 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I built a blown Methanol 1700 HP HEMI with a World aluminum water block and it failed. There are some weak points that probably limit the max HP to about 1300.
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407959
11/23/17 06:28 PM
11/23/17 06:28 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Only need 1000 HP to go 8.50
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407961
11/23/17 06:36 PM
11/23/17 06:36 PM
Superfreak OP
Superfreak OP
Car will be around 3200-3300lbs plus my 230lbs which shows 1300hp. Have not had a chance to weigh it yet.
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407963
11/23/17 06:49 PM
11/23/17 06:49 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you want to run 8.50 the car better be certified to 7.50 which adds MORE weight to the car if it isn't already up to spec. Gotta be able to cover the 8.50 in Summer heat so it better run at least 8.30's.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407966
11/23/17 07:01 PM
11/23/17 07:01 PM
Superfreak OP
Superfreak OP
Not going the 7.50 cage route.
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407967
11/23/17 07:05 PM
11/23/17 07:05 PM
PA.
"Little"John
"Little"John
PA.
OK
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407969
11/23/17 07:09 PM
11/23/17 07:09 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Any connections for aftermarket blocks in Canada? Your in Ontario if I remember correctly?
Do you have a block already or you still on the hunt?
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407984
11/23/17 07:54 PM
11/23/17 07:54 PM
Superfreak OP
Superfreak OP
I am in BC. FHO just finished machining my block and getting the pistons in so parts can be shipped to me. I had a new mega block and I got talked into an aluminum block so I sold it to Tim and then poof no more KB blocks. Piss me off cause after two yrs I decided to sell my Stage V big valve heads done by FHO and the RB/T&D roller rocker assembly (sold in 4hrs). I bought the new World block from Dave Duedeck and just need to get the intake, heads, rocker set and crank.(waiting game)
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407986
11/23/17 08:07 PM
11/23/17 08:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Was that before or after the new KB situation?
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407994
11/23/17 08:16 PM
11/23/17 08:16 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I’d like to get a low deck block to transplant all my stuff into, but that is going to be a tough task.
Do I dare say Big M here LOL.
Re: 1200-1500hp - World iron hemi block? [Re: ] #2407999
11/23/17 08:21 PM
11/23/17 08:21 PM
K
KOS Offline
KOS  Offline
K
I may have a line on a KB brand new tall deck or a RB mega....pm me if interested.im in Ontario
Re: 1200-1500hp - World iron hemi block? [Re: ] #2408001
11/23/17 08:21 PM
11/23/17 08:21 PM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^ shruggy^^^
GM?
Re: 1200-1500hp - World iron hemi block? [Re: ] #2408004
11/23/17 08:28 PM
11/23/17 08:28 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Yeah. When a guy runs a motor plate and coil over front suspension in a B body it leaves lots of room for the alternative. Believe me it is had to think that way but when you look at cost and availability it does start to look appealing.
Re: 1200-1500hp - World iron hemi block? [Re: Wookie316] #2408005
11/23/17 08:30 PM
11/23/17 08:30 PM
Mo.
racerx Offline
racerx  Offline
Mo.
iagree
Re: 1200-1500hp - World iron hemi block? [Re: ] #2408011
11/23/17 08:44 PM
11/23/17 08:44 PM
Superfreak OP
Superfreak OP
I damn near bought a big M block to build a 632. $3200 here at Mopac. I have an Alterkation front end so what's in the middle doesn't really mean sh!t to me as long as the car goes forward and back. Doing a hemi just shows how stupid I am, doing a blown hemi.......well that is just stroking the ego and because I can.LOL eek
Re: 1200-1500hp - World iron hemi block? [Re: ] #2408013
11/23/17 08:48 PM
11/23/17 08:48 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Yeah our dollar has jumped a bit, but the cross border sting is still there. Mopac knows me by name in Edmonton LOL. My wife cringes when a package shows up from there or Summit.
For what I put into my stock block stroker I could of built one heck of a Big M. And had $ left over for the TH400 with a great converter.
Re: 1200-1500hp - World iron hemi block? [Re: fast68plymouth] #2408093
11/24/17 12:46 AM
11/24/17 12:46 AM
Superfreak OP
Superfreak OP
Before. It was just at the time when a lot of guys put down their cash and were starting to wonder where the hell their blocks are.
Re: 1200-1500hp - World iron hemi block? [Re: Mopar_Rich] #2408190
11/24/17 12:06 PM
11/24/17 12:06 PM
Sweden
MikeN Offline
MikeN  Offline
Sweden
What failed och what are the weak points in your opinion?
In an earlier thread you posted (Dec 17 2015) that you had no problems with 1600 HP (fuel type not mentioned). Has there been any significant changes to the design when Bill Mitchell started selling the block (instead of the Grainger & Worrall cast World blocks)?
