What bolts to remove when pulling small block? #2407935
11/23/17 05:35 PM
11/23/17 05:35 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
What arethe easiest bolt or bolts to takeoff to pull the engine? This pic is upside-down
Still looking for LM29H1B415501, '71 Demon 340
Re: What bolts to remove when pulling small block? [Re: PAULS_340] #2407951
11/23/17 06:18 PM
11/23/17 06:18 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
There is a stud on the bottom of that mount going into the k frame. Remove that nut and leave the rest. Same on both sides.
Re: What bolts to remove when pulling small block? [Re: PAULS_340] #2407977
11/23/17 07:33 PM
11/23/17 07:33 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Yup, one on each side.
Re: What bolts to remove when pulling small block? [Re: 1E2C] #2408074
11/24/17 12:05 AM
11/24/17 12:05 AM
Motown, Mi
P
P
Motown, Mi
thank you both
Re: What bolts to remove when pulling small block? [Re: PAULS_340] #2408143
11/24/17 03:26 AM
11/24/17 03:26 AM
Are you wanting to pull the engine only or engine and transmission?
