1200-1500hp - World iron hemi block?
#2407949
11/23/17 06:14 PM
11/23/17 06:14 PM
Superfreak
Superfreak
14-71 roots blower, GRP aluminum rods, Stage V custom heads 7000rpm max. Think it will hold together? I would probably need max hp at 1300. Car is built for 8.5 so......... and no desire to go faster.
Re: 1200-1500hp - World iron hemi block?
[Re: ]
#2407950
11/23/17 06:16 PM
11/23/17 06:16 PM
Posts: 326 Alberta
Wookie316
Alberta
I’ll gladly test it for you.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: ]
#2407961
11/23/17 06:36 PM
11/23/17 06:36 PM
Superfreak
Superfreak
Car will be around 3200-3300lbs plus my 230lbs which shows 1300hp. Have not had a chance to weigh it yet.
[Re: ]
#2407963
11/23/17 06:49 PM
11/23/17 06:49 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you want to run 8.50 the car better be certified to 7.50 which adds MORE weight to the car if it isn't already up to spec. Gotta be able to cover the 8.50 in Summer heat so it better run at least 8.30's.
[Re: ]
#2407966
11/23/17 07:01 PM
11/23/17 07:01 PM
Superfreak
Superfreak
Not going the 7.50 cage route.
[Re: ]
#2407967
11/23/17 07:05 PM
11/23/17 07:05 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not going the 7.50 cage route. OK
[Re: ]
#2407969
11/23/17 07:09 PM
11/23/17 07:09 PM
Posts: 326 Alberta
Wookie316
Alberta
Any connections for aftermarket blocks in Canada? Your in Ontario if I remember correctly? Do you have a block already or you still on the hunt?
[Re: ]
#2407984
11/23/17 07:54 PM
11/23/17 07:54 PM
Superfreak
Superfreak
I am in BC. FHO just finished machining my block and getting the pistons in so parts can be shipped to me. I had a new mega block and I got talked into an aluminum block so I sold it to Tim and then poof no more KB blocks. Piss me off cause after two yrs I decided to sell my Stage V big valve heads done by FHO and the RB/T&D roller rocker assembly (sold in 4hrs). I bought the new World block from Dave Duedeck and just need to get the intake, heads, rocker set and crank.(waiting game)
[Re: ]
#2407986
11/23/17 08:07 PM
11/23/17 08:07 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Was that before or after the new KB situation?
[Re: ]
#2407994
11/23/17 08:16 PM
11/23/17 08:16 PM
Posts: 326 Alberta
Wookie316
Alberta
I’d like to get a low deck block to transplant all my stuff into, but that is going to be a tough task. Do I dare say Big M here LOL.
[Re: ]
#2408001
11/23/17 08:21 PM
11/23/17 08:21 PM
Posts: 4,070 Mo.
racerx
Mo.
Do I dare say Big M here LOL. ^^^ ^^^ GM?
[Re: ]
#2408004
11/23/17 08:28 PM
11/23/17 08:28 PM
Posts: 326 Alberta
Wookie316
Alberta
Yeah. When a guy runs a motor plate and coil over front suspension in a B body it leaves lots of room for the alternative. Believe me it is had to think that way but when you look at cost and availability it does start to look appealing.
[Re: ]
#2408011
11/23/17 08:44 PM
11/23/17 08:44 PM
Superfreak
Superfreak
I damn near bought a big M block to build a 632. $3200 here at Mopac. I have an Alterkation front end so what's in the middle doesn't really mean sh!t to me as long as the car goes forward and back. Doing a hemi just shows how stupid I am, doing a blown hemi.......well that is just stroking the ego and because I can.LOL
[Re: ]
#2408013
11/23/17 08:48 PM
11/23/17 08:48 PM
Posts: 326 Alberta
Wookie316
Alberta
Yeah our dollar has jumped a bit, but the cross border sting is still there. Mopac knows me by name in Edmonton LOL. My wife cringes when a package shows up from there or Summit. For what I put into my stock block stroker I could of built one heck of a Big M. And had $ left over for the TH400 with a great converter.
[Re: fast68plymouth]
#2408093
11/24/17 12:46 AM
11/24/17 12:46 AM
Superfreak
Superfreak
Was that before or after the new KB situation? Before. It was just at the time when a lot of guys put down their cash and were starting to wonder where the hell their blocks are.
[Re: Mopar_Rich]
#2408190
11/24/17 12:06 PM
11/24/17 12:06 PM
Posts: 81 Sweden
MikeN
Sweden
I built a blown Methanol 1700 HP HEMI with a World aluminum water block and it failed. There are some weak points that probably limit the max HP to about 1300. What failed och what are the weak points in your opinion? In an earlier thread you posted (Dec 17 2015) that you had no problems with 1600 HP (fuel type not mentioned). Has there been any significant changes to the design when Bill Mitchell started selling the block (instead of the Grainger & Worrall cast World blocks)?
[Re: ]
#2408206
11/24/17 12:38 PM
11/24/17 12:38 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
14-71 roots blower, GRP aluminum rods, Stage V custom heads 7000rpm max. Think it will hold together? I would probably need max hp at 1300. Car is built for 8.5 so......... and no desire to go faster. WHO YOU TRYIN TO KID!! us or yourself? NO DESIRE TO GO FASTER
[Re: ]
#2408237
11/24/17 02:10 PM
11/24/17 02:10 PM
Posts: 4,206 New York
polyspheric
New York
Iron block + blower = safe. Same power from NA or nitrous would be worse stress.
What brand 14-71? What does the discharge window and manifold look like?
Boffin Emeritus
[Re: ]
#2408342
11/24/17 06:00 PM
11/24/17 06:00 PM
Superfreak
Superfreak
Littlefield standard,prepped for gas. full open on the bottom IIRC. Manifold will be a Stage V piece. I have 2 - Quickfuel 1050 blower domi's, CP blower pistons, crank will be a Bryant billet center counter weighted piece.
[Re: ]
#2408441
11/24/17 11:07 PM
11/24/17 11:07 PM
polyspheric
New York
I know full rotor exposure doesn't seem critical for race, but (as in all helixed rotors) all the air is in the triangle formed by the rotor's relative positions just behind the drive nose. Air behind that point is just pulled back into the case and re-heated. It looks to me that masking the case would be easy (Eaton just closes it up, no special shape) but it may mean moving the case to the rear of the manifold - which will move your pulley out of line. Some pictures may exist of a masked case on a manifold to hint at a good distribution spot (although some OEM Eaton manifolds are just open boxes).
Anyone read anything on this?
Boffin Emeritus
