Oil pressure sender vs Oil pressure Gauge
#2407813
11/23/17 01:13 PM
11/23/17 01:13 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
The stock gauge in my 70 Charger scales up to 80 psi. If I install a sending unit with the 100 stamped on the side, will my gauge still be fairly accurate? I think that the 100 on the sender indicates it should be used with a gauge with max scale of 100.
Thoughts?
68 Charger 70 Cuda
Re: Oil pressure sender vs Oil pressure Gauge
[Re: Alaskan_TA]
#2408418
11/24/17 09:44 PM
11/24/17 09:44 PM
Posts: 7,664 IN
ahy
IN
You can get a manual gauge & plumb it in with a T fitting, so your sender & the manual gauge are both in operation at the same time to compare them. Good idea. Also neither the sending units nor the gauges are calibrated/accurate. A mechanical gauge to check is a good idea. Also, the electric gauges are slooooow. I have a fully functioning factory gauge on my Challenger and also run a mechanical to get faster response. If I loose OP briefly on the road course, I want to know!
[Re: 71birdJ68]
#2408507
11/25/17 01:31 AM
11/25/17 01:31 AM
Posts: 4,950 WI
Dcuda69
WI
Good question. My machine shop guy is a Ford man, and he remembers Ford had two sending units, one said 80, and the other had 100 on it. I'd like to know myself. New sending units today don't have that on them. Gotta remember the older Ford vehicles had dash gauges that read...L(low)Normal(which was most of the gauge sweep)and H(High)Nobody really knew what any of that meant but they had full "instrumentation". Like most electrical gauges....highly inaccurate.
[Re: Dcuda69]
#2408518
11/25/17 02:14 AM
11/25/17 02:14 AM
Posts: 10,585 Freeport IL USA
poorboy
Freeport IL USA
Good question. My machine shop guy is a Ford man, and he remembers Ford had two sending units, one said 80, and the other had 100 on it. I'd like to know myself. New sending units today don't have that on them. Gotta remember the older Ford vehicles had dash gauges that read...L(low)Normal(which was most of the gauge sweep)and H(High)Nobody really knew what any of that meant but they had full "instrumentation". Like most electrical gauges....highly inaccurate. Most of the Mopars I've owned have similarly marked gauges, oil pressure and temp, and amp gauges with the high end and the low end with or without numbers, a center mark, or a "normal" range. You have no idea what any of the marks are suppose to mean. I don't hold much faith in any factory gauges. Gene
[Re: FC7cuda]
#2408552
11/25/17 03:45 AM
11/25/17 03:45 AM
Posts: 5,445 So Cal
Sinitro
So Cal
If U want total pinpoint accuracy, U better install a quality aftermarket guage.. The OE guage is fine for approximating the amount of oil pressure, will indicate the typical fluctuations when the oil is cold or hot as well as increasing with RPM.. In my 70 RR, I have both the ralley dash oil pressure guage and a mechanical guage mounted directly to the engine, not piped inside.. This gives U the best of both, OE guage for basic tracking while driving and EZ access to the mechanical guage for more accurate pressure readings/troubleshooting/monitoring... Just my $0.02...
