Fender tag #2407663
11/23/17 01:02 AM
11/23/17 01:02 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
your opinion on a chally fender tag which has a n41 and a n42. It would seen it it contradicts each other. One say it is an Exhaust with out tips the other says it has tips. You think it is a mistake on the tag?
Re: Fender tag [Re: 70 buzz] #2407674
11/23/17 01:19 AM
11/23/17 01:19 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
N41 is dual exhaust.
N42 is bright tips ON dual exhaust.
They go together quite well.
If you have reason to suspect the tag, you can email a photo of it to me at sixpak340(insert at symbol here)att.net & I can look it over for you.
Re: Fender tag [Re: Alaskan_TA] #2407712
11/23/17 03:01 AM
11/23/17 03:01 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
on-line decoders have many issues/errors & that's one of them
N41 - dual exhaust (CAN STAND ALONE)
N42 - bright exhaust tips (CAN'T EXIST w/o N41, at least on e-bodies)
