Wrist Pin Failure - Why and Now What? #2407209
11/22/17 03:08 AM
11/22/17 03:08 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
To try and make a long story short, at least 4 wrist pins and associated rod ends are galled (I only took one apart and the galling was severe in the rod end and the pin was also toast).
This is my old detuned race motor that was in my street/strip car. Has old Arias dome pistons that had the dome cut down - the pistons look fine. I had the motor rebuild (and detuned) and it does not have a lot of time on it since the rebuild. The motor has home ported 906 heads on it and 9:1 compression.
Took the motor apart because it had a very annoying noise in it that was driving me nuts and the converter went south so I decided to go back with the original 383.
Was getting ready to reassemble this motor (no plans for it other than a viable spare and was tripping over the parts) when I found the bad wrist pins.
The pins are floating. What would have caused it and now how do I fix it on the cheap?
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2407220
11/22/17 05:05 AM
11/22/17 05:05 AM
Two things can lead to galling, lack of oil and lack of adequate clearance for the oil to go into the pistons, wrist pin bores and rod pin bores shruggy
Or maybe even bad oil shruggy
I would see about honing the pistons, rod pin ends and polishing the pins to see if they are savable scope I hope so luck
I like loose wrist pin to rod pin bushing clearances, .0010+ on .990 pins, more for bigger pins up
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2407235
11/22/17 07:55 AM
11/22/17 07:55 AM
Washington
madscientist Offline
Washington
I've seen pins that were bending gall like that.
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2407292
11/22/17 11:55 AM
11/22/17 11:55 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If the pin and piston bore are not lubercated when installed galling can occur on initial fire up and can get worst after running time.They usually make a knocking sound as the bore galling creates loose wear.
Re: Wrist Pin Failure - Why and Now What? [Re: B G Racing] #2407342
11/22/17 01:25 PM
11/22/17 01:25 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Are they 1.094 or .990 od? Trend and others have oversized wrist pins available. IDK about 1.094 but I know they have them in .991 to .994. Also look and see if the pins have forced pin oilers. On a street car you need it for sure.
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2407343
11/22/17 01:27 PM
11/22/17 01:27 PM
P
Porter67 Offline
Porter67  Offline
P
I always wondered if the pins were tight on the rod, wouldnt they still act like a pressed pin oem rod setup?
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2407395
11/22/17 03:41 PM
11/22/17 03:41 PM
A727Tflite Online content
A727Tflite  Online Content
Floating pins have to float. If they seize up in the rod you can likely knock out one of the wrist pin locks - or both. Plus when you seize up a pin in the rod you cause all kinds of issues with skirt to bore - the rod has to float side to side on the crank journal - if it doesn't you can have bearing issues too.
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2407398
11/22/17 03:50 PM
11/22/17 03:50 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Thanks for all the replies. Since those are stock rods they owe me nothing and they have not had an easy life.
For $400 I will put in a set of Scat rods that are bushed. I wonder if some of the issue was the fact that the rod was not bushed.
Will suck it up and re-balance the assembly.
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2407406
11/22/17 04:00 PM
11/22/17 04:00 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
When we used to run our stock rods like that (unbushed) years ago we would drill a 1/8 hole in the top of the rod and champher it to give the pin some oil. it helped some but not totally.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Wrist Pin Failure - Why and Now What? [Re: pittsburghracer] #2407410
11/22/17 04:06 PM
11/22/17 04:06 PM
Mt. Eden Ky.
Hemi Allstate Online content
Hemi Allstate  Online Content
Mt. Eden Ky.
I know that some SBC and BBC came from the factory with floating pins and without bushings. 69 302 for example.
The drill the top and chamfer was a common mod for those too.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2407463
11/22/17 05:30 PM
11/22/17 05:30 PM
tsk You have learned a valuable life lesson from this ,huh whistling
Buynig or choosing cheap parts in a non stock Hi Po motor will buy you future problems, usually shruggy
Good luck from now on thumbs
Re: Wrist Pin Failure - Why and Now What? [Re: pittsburghracer] #2407469
11/22/17 05:40 PM
11/22/17 05:40 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
These rods do have that mod.
Re: Wrist Pin Failure - Why and Now What? [Re: Cab_Burge] #2407474
11/22/17 05:47 PM
11/22/17 05:47 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
You need to understand that when this motor was originally put together cheap aftermarket rods and cranks did not exist. It was a great motor. When we detuned it the crank went THUD when put on the ground so it got replaced. Other than that was a great motor for a very long time.
The replacement motor is a 2001 megablock with Eagle parts. The new build is a new "The Block" with all Molnar internals. This is just a low power spare motor now.
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2407811
11/23/17 01:08 PM
11/23/17 01:08 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
not enough clearance, my twocents If it even matters at this point. Steel on steel is asking for trouble though.
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2407869
11/23/17 02:37 PM
11/23/17 02:37 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Back in the 80's we all ran the stock rods, heavy TRW pistons and floated the rods the same way - steel on steel with the 1/8th inch oiling hole. just about every engine I ran like that eventually galled the pins at the rod - we just changed the pins honed the rod and kept going. Nothing wrong with that old set-up it just had its limitation back then.
Re: Wrist Pin Failure - Why and Now What? [Re: DoubleD] #2407916
11/23/17 04:31 PM
11/23/17 04:31 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Maybe the clearance changed as the pin got hotter and made it gall?
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2408015
11/23/17 08:56 PM
11/23/17 08:56 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
For some reason I don't remember the pins to be floating when the motor was originally built but I could be wrong on that. Perhaps they got converted at some point.
I do remember that very early on during a rebuild found several pins blued. The machine shop honed the pistons/rod (not sure which) replaced a couple pins and cleaned one or 2 up. Never had a repeat problem until now.
These rods have seen 6800 rpm far too often - it might be a good omen for them to fail like this just so that I replace them with a reasonable rod.
Re: Wrist Pin Failure - Why and Now What? [Re: markz528] #2408049
11/23/17 10:48 PM
11/23/17 10:48 PM
Mt. Eden Ky.
Mt. Eden Ky.
You said the torque converter went bad. How is your thrust bearing looking.
I have seen the wrist pins blue when the converter shoves the crank forward and rear face of the thrust gets it too of course.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Wrist Pin Failure - Why and Now What? [Re: Hemi Allstate] #2410441
11/29/17 12:20 AM
11/29/17 12:20 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Mark
Thrust bearing is not great and needs replacing. Not total toast but not good.
