Hellcat swap, automatic trans ? #2407139
11/22/17 12:26 AM
11/22/17 12:26 AM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
Ok, I'm just starting a Hellcat swap into a 71 Barracuda. I want to use the automatic trans that came out of the donor car but not sure about the wiring issues. I plan on using the new plug and play wire kit from Chrysler for the engine but it doesn't have provisions for the transmission. Can anybody shed some light on this subject?
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2407150
11/22/17 12:43 AM
11/22/17 12:43 AM
USA
hudsonhornet7x Offline
USA
The trans is going to cause you some troubles. With these new cars everything is interconnected. I also do not think that the 8 speed has aftermarket support for harnesses.
Personally I would run a 4l80E behind the Hellcat and enjoy the car that way.
Re: Hellcat swap, automatic trans ? [Re: hudsonhornet7x] #2407159
11/22/17 12:58 AM
11/22/17 12:58 AM
S.E. Missouri
S.E. Missouri
Someone else mentioned that too. Where would I find adaptors?
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2407161
11/22/17 12:59 AM
11/22/17 12:59 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
1974 Roadrunner
1967 Charger
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2407199
11/22/17 02:28 AM
11/22/17 02:28 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
If using a donor car you may find some tips here:
https://www.youtube.com/watch?v=qRh5KIVO3CM
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2407396
11/22/17 03:44 PM
11/22/17 03:44 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
I have a friend who put the 392 crate in a 68 Dart and used a 7 or 8 speed Chevy trans, works very good. I'll talk to him to get the info than pass it on. Many pieces have to be added to use that 8 speed trans, from wheel censers to output and drive shaft changes (no slip yoke)
Mike
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2407593
11/22/17 10:37 PM
11/22/17 10:37 PM
S.E. Missouri
S.E. Missouri
Thanks. It looks like the GM 4L80 will be the best option. It has a stand alone tuner for it and Chrysler has a stand alone kit for the engine. The car has a 94 Corvette rear end in it already and an Altercation front end.
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2409929
11/28/17 01:07 AM
11/28/17 01:07 AM
S.E. Missouri
S.E. Missouri
Will a built 5-45RFE 2wd trans hold up to the Hellcat horsepower? This car will not be beat on like a race car but will be driven.
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2437226
01/19/18 12:46 AM
01/19/18 12:46 AM
S.E. Missouri
S.E. Missouri
Went with a GM 4L80 with a Mopar bell housing adapted to it. It's a stage V from RPM transmissions. It fits the car very well and has a stand alone tuner for the trans which plugs into the HOLLEY DOMINATOR wiring kit I'm using. I'll try to post pics later. The cars previous owner cut the floor for a modern 5 spd and the 4L80 is much smaller so....need to fab a tunnel now.
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2437261
01/19/18 01:36 AM
01/19/18 01:36 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Good plan passing over the 545rfe. It seems any power over stock kills them
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2438742
01/21/18 11:19 PM
01/21/18 11:19 PM
Wooster, Ohio
K
kpzbee Offline
kpzbee  Offline
K
Wooster, Ohio
I'm using one of these 5.7L-350AT with a 4L60E behind an Eagle. http://www.wilcap.com/mopar.html
It's a really nice piece that's 3/4" thick.
"It's funny how one project eventually leads (or forces) you into another one.
It's really just one endless project designed to induce insanity and bankruptcy."
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2641641
04/05/19 04:24 PM
04/05/19 04:24 PM
Vista, CA
71Chip Offline
71Chip  Offline
Vista, CA
You do not need a standalone controller for the 4L80 if you already have the holley dominator EFI. I am not sure if you mean Dominator carb or EFI.
The Dominator EFI has a wiring harness for the 4L80 and can run it directly as well or better than any standalone controller.
So with the single dominator pcm you can run the hellcat and the trans.
71 Challenger
Re: Hellcat swap, automatic trans ? [Re: 71Chip] #2671469
06/29/19 10:23 AM
06/29/19 10:23 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
you can run the 8 speed auto now.
Re: Hellcat swap, automatic trans ? [Re: AeroMonte] #2674773
07/06/19 11:00 AM
07/06/19 11:00 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Nope it'll puck in about an hour.
Sound German Automotive is your go to for a controller for the 8speeds trans ,
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
