Page 1 of 5 1 2 3 4 5
Mopar RB 572 1000 HP Project 1970 Cuda #2406851
11/21/17 03:06 PM
11/21/17 03:06 PM
Italy
Raffaplymouth60 Offline OP
Italy
Hello i'm Raffa from Italy just bought now this Engine RB 572 with Indyheads 440-1 , i'm looking for assembly and install in my 70 Cuda ! if someone have advice for the oiling system and vacuum system ... i'm undecided if install single or dual line pump ...
Thanks in advance
Raffaele
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406856
11/21/17 03:14 PM
11/21/17 03:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Looks like some nice parts. I wonder why the porting work on the intake wasn’t finished
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: pittsburghracer] #2406864
11/21/17 03:25 PM
11/21/17 03:25 PM
Italy
Italy
Yep , im looking also for buy 2 1/4 headers from TTI , now i have 2"
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406867
11/21/17 03:30 PM
11/21/17 03:30 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I think you need a dual line pickup for the power, rpm and engine size you are building. I just don't know if that oil pan will fit the bill.
[image][/image]
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406875
11/21/17 03:44 PM
11/21/17 03:44 PM
an8sec70cuda Offline
A single line will work fine, but nothing wrong w/ going dual. The pan will be OK, as long as you have good oil drainback and don't flood the heads.
For a vacuum pump...Moroso, GZ, or Star make good pumps. Just DON'T use an Aerospace Components pump. Looks like you already have a Moroso pump.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: sgcuda] #2406880
11/21/17 03:49 PM
11/21/17 03:49 PM
Italy
Italy
i fear of dual line because i have stock solid engine mounts , not plate , i will send more pics of my single and dual line oiling , Thanks
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: an8sec70cuda] #2406885
11/21/17 03:55 PM
11/21/17 03:55 PM
Italy
Italy
ooook ! i have moroso pump and all hose but i dont know if fit with power steering , in my old 496 i used crankcase evac system for 10 years with good result .. but this can work on 572 ???
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406899
11/21/17 04:44 PM
11/21/17 04:44 PM
Italy
Italy
440-1 heads
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406900
11/21/17 04:45 PM
11/21/17 04:45 PM
Italy
Italy
Oil Pump two line
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406901
11/21/17 04:48 PM
11/21/17 04:48 PM
Italy
Italy
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406902
11/21/17 04:50 PM
11/21/17 04:50 PM
Italy
Italy
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406906
11/21/17 04:57 PM
11/21/17 04:57 PM
AndyF Offline
AndyF  Offline
You'll just have to put it together and see what fits and what doesn't. Then you'll have to decide what to modify and what to leave alone. You are trying to cram 10 pounds of stuff into a 5 pound bag.
It really comes down to how hard you are going to drive the car. If you are racing it hard then you'll want to put the best oiling system on the engine even if you need to cut things up. If you are just cruising the car then use what fits.
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406907
11/21/17 04:59 PM
11/21/17 04:59 PM
Italy
Italy
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: AndyF] #2406910
11/21/17 05:01 PM
11/21/17 05:01 PM
Italy
Italy
YES RACE 20 PASS AT YEAR , AND DRIVE SOME TIME ON STREET , LOW RPM CRUISIN
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: AndyF] #2406913
11/21/17 05:07 PM
11/21/17 05:07 PM
Italy
Italy
Thanks for the advice
at the end of the week i will put the engine on stand and check all measures,clearances,everything .. i will decide for the lubrication , but i want a consistent engine , the problem is the mounts is factory and have power steering , like my older 496 with power steering and evac system i had made several pass at low 9 sec for 10 years
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406916
11/21/17 05:18 PM
11/21/17 05:18 PM
Italy
Italy
Single line Pump
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: AndyF] #2406920
11/21/17 05:31 PM
11/21/17 05:31 PM
iagree
I'm putting a pump gas 572 C.I. Hemi motor together for a local customer, it is going in a 1970 Challenger street and show cruiser. I'm using a eight quart aluminum road race type oil pan with a single line static pickup in it thumbs
I mounted the Milidon static pick up in the left rear corner of that pan, I'm using the older model cast aluminum Milidon oil pump with the front mounted cast in pick up boss. I blocked off the other two pick ups, one in the World block above the oil pump mounting boss and the other in the black billet Milidon pump cover, that cover is for the remote mounted oil filter thumbs
Are you going to restrict the oil to the rocker shafts? If not you should thumbs
I use a .040 restrictor made from a #6 brass set screw tapped into the oil line fitting in each Indy 440-1 head scope
Good luck on your deal, your car collection is impressive bow up
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406936
11/21/17 06:09 PM
11/21/17 06:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My 572 runs a single line Indy max pump with the same pick-up you have (mine has one hole plugged). Over 500 passes at 7100, never hurt a bearing. .003 rod, .004 main clearance. Push rod oil with .050" restriction. It also runs a GZ vacuum pump. They have a nice product and great customer service.
Doug
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2406958
11/21/17 06:56 PM
11/21/17 06:56 PM
Italy
Italy
ok Guys.. i had .040 restrictor on my 496 oiling hose .. very nice .. no problem .. i will check the room available and decide .if put singke or dual. i think this engine will run at 7200 rpm
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: dvw] #2406959
11/21/17 06:57 PM
11/21/17 06:57 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
looks like a fun project up
