904 shifts from 1st to 3rd??? #240684
03/02/09 09:01 AM
03/02/09 09:01 AM
Midlothian TX USA
Dallasdan Offline OP
Midlothian TX USA
I have a 904 that shifts from 1s to 3rd - no second gear at all. Anyone have some helpful tips? Is the front band too tight or is this the band in the pan?
Re: 904 shifts from 1st to 3rd??? [Re: Dallasdan] #240685
03/02/09 09:44 AM
03/02/09 09:44 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
It is possible the band is too loose, or the anchor is broken.
Drop the pan and take a look.
Re: 904 shifts from 1st to 3rd??? [Re: fox] #240686
03/02/09 11:00 AM
03/02/09 11:00 AM
scratchnfotraction Offline
band may be worn
adjust the bands and try it
I tighten mine up when this happens and I allways get 2nd back
and the 2nd or 3rd time I do this its deff on its way out and I start looking for a replacement asap
my jy yard tranny has been in 28 days now,the one I removed eat the band and you should see the groove in the drum....yea it used now
Re: 904 shifts from 1st to 3rd??? [Re: fox] #240687
03/02/09 11:01 AM
03/02/09 11:01 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I second that strut has fallen out or servo is stuck would be my guess. sounds like the second gear band (kick down) is not applying
Re: 904 shifts from 1st to 3rd??? [Re: Dodgem] #240688
03/02/09 08:16 PM
03/02/09 08:16 PM
Midlothian TX USA
Midlothian TX USA
Thanks ALL for the info! Guess I have some work ahead of me!
Re: 904 shifts from 1st to 3rd??? [Re: Dallasdan] #240689
03/02/09 08:48 PM
03/02/09 08:48 PM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
You didn't by any chance run it w/o the kickdown linkage did you?
Re: 904 shifts from 1st to 3rd??? [Re: slantzilla] #240690
03/03/09 10:09 PM
03/03/09 10:09 PM
Midlothian TX USA
Midlothian TX USA
I am pretty sure this trans was put through HELL - I got this ramcharger with a blown engine - and replaced the engine only to find the trans wasn't too hot either. I have a 727 I think I will be putting in soon.
Re: 904 shifts from 1st to 3rd??? [Re: slantzilla] #240691
03/05/09 10:15 AM
03/05/09 10:15 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Seen that more than once. Same results too. 1st to 3rd.
