Engine Markings... pls help!!! #240679
03/02/09 07:52 AM
03/02/09 07:52 AM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
Hello mopar friends
can anybody tell me what this markings on this 1970 made engine means?
I mean specially K7 and K4
but maybe al of the numbers...
thx
David
___________________________ .......plymouth tells it like it is...!
Re: Engine Markings... pls help!!! [Re: plyrr69] #240680
03/02/09 06:33 PM
03/02/09 06:33 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Re: Engine Markings... pls help!!! [Re: plyrr69] #240681
03/02/09 06:44 PM
03/02/09 06:44 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
K could be assembly Plant---Toluca is a code K the 7 could be for year, but not positive, what is casting date on your block, does it have 70 casting date.
Re: Engine Markings... pls help!!! [Re: 268RTs4ME] #240682
03/02/09 08:06 PM
03/02/09 08:06 PM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
yes 70 casting, i am searching for a code for overbore...
Re: Engine Markings... pls help!!! [Re: plyrr69] #240683
03/02/09 09:51 PM
03/02/09 09:51 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
FW340P31770423;
F - Series (model year) 1970
W - Windsor, Ontario engine assembly plant
340 - 340 cid
P - Premium fuel required
3177 - Final assembly date from the 10,000 day calendar - April 9, 1970
0423 - 423rd engine assembled at this plant on the date above.
The 1970 TSB that covers the engine markings does not mention a "K" at all. You can read it at this link if you like - http://www.hamtramck-historical.com/1970-Dodge-TSB-Index.shtml Drop down to Chapter 25 in the grid & read D70-25-1, there are 8 pages.
