I installed my brace yesterday. Mine is a 2WD diesel. I had to grind a little half moon on the top of the plate just behind the forward most bolt hole for frame clearance. Not a big deal and it's only about the radius of a quarter.
I did not have to drill the front cross support though as it was already slotted there. I couldn't find 1.75" long bolts so I used 2" bolts and they fit just fine.
Thanks for getting these made again!
