73-74 roadrunner upper door panels fit 71-72?
#2405434
11/18/17 01:54 PM
11/18/17 01:54 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
Just bought a set of upper door panels from legendary, and learned that you need to cannibalize your old panels and reuse the metal frames, front and rear to make them work, thus destroying the old ones. My existing panels are nice drivers and would prefer to keep them. I found a well used set of uppers from a 73-74 roadrunner. Does anyone know if the metal frames are the same between 71-72s and 73-74s?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 73-74 roadrunner upper door panels fit 71-72?
[Re: RSI700VIPER]
#2405509
11/18/17 04:43 PM
11/18/17 04:43 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
71/72 Chargers are a diff monsters from 73/74 Chargers BUT I think all 71/74 Plymouths upper DOORS ( MAYBE not quarters due the diff opening shape ) will interchange.
HOWEVER, I think if 73/74 is somehow a bit diff, COULD be made to fit on 71/72 ?
just thinking out loud
[Re: RSI700VIPER]
#2405518
11/18/17 05:09 PM
11/18/17 05:09 PM
NachoRT74
Valencia, España
looking at the rear quarter shape of 73/74.... I think will be posible because the slope seems to be the same up to the cut where is where the upper panel reachs, just the "vertical" section seems to change and this is covered by the sail panel
HOWEVER, mostly sure 73/74 hardtop/coupe Charger into a 71/72 Plymouth will be posible too... quarter window opening shape is the same
IN FACT a full 73/74 Charger hardtop/coupe setup should work on a 71/72 Plymouth... that gives more posibilities
[Re: RSI700VIPER]
#2405611
11/18/17 07:58 PM
11/18/17 07:58 PM
RSI700VIPER
NW New Jersey
Thanks all. I think I'll give it a try.
