Hemi compression ratio
#2405048
11/17/17 04:23 PM
11/17/17 04:23 PM
Posts: 205 Everywhere
Lost in life
Everywhere
Yesterday when I took my block to the builder who is putting together my 572 Hemi he broached an interesting topic regarding compression ratio. He said that 700HP wouldn't be an issue on pump gas, but wondered outloud if I didn't plan on driving the car much why not go to 12.5 or 13.0 and (in his words).."make it run like a hemi should". What say the group on his thinking? Realistically the dart is going to be a toy and most likely will be driven less than 200 miles a year.
This will be a 4 speed, that currently has a 4.88 dana in the rear. Thoughts?? Thanks in advance.
Re: Hemi compression ration
[Re: Lost in life]
#2405052
11/17/17 04:27 PM
11/17/17 04:27 PM
Posts: 4,457 Washington
madscientist
Washington
Do it and cam accordingly.
[Re: Lost in life]
#2405057
11/17/17 04:30 PM
11/17/17 04:30 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Well if you only get 5 mpg you will need 40 gallons of gas to drive 200 miles. Pump premium at 3.50 a gallon is $70 a year, 110 leaded is about $10 gallon so it will cost $200 or $130 a year extra, if $130 a year is gonna break your buget than you probably should not be driving a gen II hemi. Also the leaded race gas tends to last longer in storage than pump gas.
[Re: HotRodDave]
#2405063
11/17/17 04:41 PM
11/17/17 04:41 PM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
Well if you only get 5 mpg you will need 40 gallons of gas to drive 200 miles. Pump premium at 3.50 a gallon is $70 a year, 110 leaded is about $10 gallon so it will cost $200 or $130 a year extra, if $130 a year is gonna break your buget than you probably should not be driving a gen II hemi. Also the leaded race gas tends to last longer in storage than pump gas. LOL...take it from a past Hemi owner....money is no object when you mash that right pedal for the first time....
71 440-6 4spd & 69 Hemi 4spd
[Re: Lost in life]
#2405080
11/17/17 05:28 PM
11/17/17 05:28 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
What comp were you thinking?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Lost in life]
#2405114
11/17/17 06:38 PM
11/17/17 06:38 PM
Posts: 2,677 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
If you do that your life will be miserable. My buddy has a car like that and it's such a hassle/expense to drive it he doesn't drive it anymore, he can't enjoy it and now talks about selling it. Stick with pump gas. This isn't the old days. You can make all the power you want on pump gas with no downside.
2011 Drag Pak Challenger
[Re: Lost in life]
#2405154
11/17/17 08:03 PM
11/17/17 08:03 PM
Posts: 12,414 Taxes & Virus's R-US, NY
Dragula
I have personally run 11.6:1 in an iron block alum headed hemi on the street for years. My current all alum 605 is 11.2:1 and neither are engine had any issue with pump gas. I know of multiple folks running 12:1 in big Hemis on pump gas.
So if your starting from scratch, go big or go home. Use the thinnest .027 Cometic gaskets at 12:1, and later, if it does give you an issue, switch them out for thicker .041's and back it off..
Now with all this dizzying thoughts of massive Hp improvements, remember, you need good eye on your timing and your carb jetting.
If your going to put some 25 year old reproduction carbs on it and a stuffy dual plane intake....You may want to reconsider.
PS...My 800hp 605 Hemi is for sale
[Re: Lost in life]
#2405193
11/17/17 09:58 PM
11/17/17 09:58 PM
Posts: 12,245 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I spoke to Ray Barton about this subject when I was choosing parts for my 540. He suggested 10.5 with the 250* cam. I thought I wanted more comp than that, but he said the extra hassle with the fuel wasn't worth the few extra ponies.
I took his advice and my mild street 540 made 700hp on the engine dyno. I run 91 pump with no problems. I probably could have went with more comp and still used pump premium, but you never quite know where the line is between just enough and too much.
Anybody have a program that can figure the difference in HP between 10.5 and 12.5 comp ratios on the OP's combo?
Master, again and still
[Re: Lost in life]
#2405315
11/18/17 03:25 AM
11/18/17 03:25 AM
Superfreak
Superfreak
For what you will spend on the hemi, you might as well go buy the demon.
[Re: Lost in life]
#2405460
11/18/17 03:06 PM
11/18/17 03:06 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
My street tires are 16.5X31,I race on 10.5w both M/T tires.Please don't think your getting ANY traction on the street from a dead stop weather your 10: or 15:1!
