indy max block oiling #240474
03/01/09 10:06 PM
03/01/09 10:06 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
I saw them talking about drillng out the holes in between the lifters. Did anybody try it and run yet to see if it helped. I'm about to put mine together and want to try something first.
Re: indy max block oiling [Re: plycuda] #240475
03/01/09 10:28 PM
03/01/09 10:28 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Did you get the block drilled for pushrod oiling?
Re: indy max block oiling [Re: boatracer572] #240476
03/01/09 10:40 PM
03/01/09 10:40 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
no, I'm gona try the spray bars. I tryed to call indy' that was before they bought predator and they acted like their normal self. told me those heads are junk and gave me a bunch of crap so I decided they aren't getting any of my money. I bet now that they are making them they are the greatest things in the world.
Re: indy max block oiling [Re: plycuda] #240477
03/01/09 11:02 PM
03/01/09 11:02 PM
San Jose Ca.
San Jose Ca.
You may have a problem burning up pushrods with the spray bars!you could build a oil manifold
with brake line and drill and tap every lifter bore to pushrod oil! I have seen It done many times before!
Re: indy max block oiling [Re: boatracer572] #240478
03/01/09 11:16 PM
03/01/09 11:16 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Many, many seasons with spray bars, no problems, a friend of mine has been running them at least 5 years longer than me, never replaced a single valve train part. No need to drill the lifter bores for this.
I do suggest running ball/ball end push rods though. And have cup adjusters..
Re: indy max block oiling [Re: Bob_Coomer] #240479
03/01/09 11:22 PM
03/01/09 11:22 PM
San Jose Ca.
San Jose Ca.
I also ran spray bars for years with my 440-1 heads,But that was with valve springs that were
much weaker than the ones that I currently run (1290lbs open)or the ones that plycuda runs!
Re: indy max block oiling [Re: boatracer572] #240480
03/01/09 11:28 PM
03/01/09 11:28 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Valve springs will be the last thing to burn up from lack of oil....
I ran spring pressures, near 800lbs open pressure. IMO I don't see a bunch of extra heat coming off the valve springs due to more spring pressure. If anything gets burnt up, it will be the little parts in the top, push rod cups, adjusters etc. I know personally 4-5 guys running the Jesel stuff with zero problems besides me. Just stating my experiences..
Re: indy max block oiling [Re: boatracer572] #240481
03/01/09 11:56 PM
03/01/09 11:56 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Like this.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: indy max block oiling [Re: Bob_Coomer] #240482
03/02/09 12:07 AM
03/02/09 12:07 AM
San Jose Ca.
San Jose Ca.
I was refuring to the excessive spring pressure burning up pushrod tips and spring cups because of
lack of pressurized oil!My INDY stuff lived a long time with spray bars and valve springs that were 850lb. open! I wouldent even attempt a spray bar with what I have now!
Re: indy max block oiling [Re: go green] #240483
03/02/09 12:21 AM
03/02/09 12:21 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
Like this.
Yikes, I want to switch my Indy block to push rod oiling. Is this the only way to do it?
Re: indy max block oiling [Re: Darryls-Demon] #240484
03/02/09 01:23 AM
03/02/09 01:23 AM
land of the free
ts racer Offline
ts racer  Offline
land of the free
Spray bars are fine, their are many guys running low 7's with spray bars with no problems..
Re: indy max block oiling [Re: go green] #240485
03/02/09 07:42 AM
03/02/09 07:42 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Like this.
Wow that's alot of hassle for pushrod oiling
Re: indy max block oiling [Re: ts racer] #240486
03/02/09 09:10 AM
03/02/09 09:10 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I agree with TS, spray bars work just fine. Use quality parts, pay attention to detail and everything works just fine. If I had to maniflod/plumb a block like that, I'd just have it drilled out. Thats a lot of work, but I am sure it works.
RIP Monte Smith
Re: indy max block oiling [Re: CompWedgeEngines] #240487
03/02/09 10:49 AM
03/02/09 10:49 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Can any standard block be drilled for push rod oiling, and does anyone have a pic?
Re: indy max block oiling [Re: Dragula] #240488
03/02/09 10:54 AM
03/02/09 10:54 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Why not just drill the block for hydraulic lifter oiling?It's the same as stock oiling.
Re: indy max block oiling [Re: B G Racing] #240489
03/02/09 12:22 PM
03/02/09 12:22 PM
Dragula Offline
Dragula  Offline
Didn't even know there was a difference, please explain, because my last one ate evry push rod I put in it.
Re: indy max block oiling [Re: Dragula] #240490
03/02/09 12:50 PM
03/02/09 12:50 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Indy blocks can be drilled(blanks at rear of block)for conventional lifter oiling passages.Drilling is done from the back to the front passing through each lifter bore,a must for hydraulic lifter or pushrod oiling.Indy offers this on their aluminum blocks for $250.A competent machine shop can also do the job.
Re: indy max block oiling [Re: B G Racing] #240491
03/02/09 02:16 PM
03/02/09 02:16 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
I called a bunch of machine shops and all of them said they can't do it. after talking to indy like I said they will not get any of my money.
Re: indy max block oiling [Re: plycuda] #240492
03/02/09 02:25 PM
03/02/09 02:25 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Muscle Motors Bushed and drilled mine for pushrod oiling
just be prepared to wait a really long time to get anything worked on back from them
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: indy max block oiling [Re: plycuda] #240493
03/02/09 06:36 PM
03/02/09 06:36 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I wouldn't let the best heart surgeon operate on me if I didn't like his attitude either.
