Page 3 of 3 1 2 3
Re: MSD distributor taking timing out [Re: moparx] #2404477
11/16/17 01:49 PM
11/16/17 01:49 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
Gonna get an extra screw and drill another hole. Will i need too grind flats in the shaft where the screw hold it?
Re: MSD distributor taking timing out [Re: mopar dave] #2404510
11/16/17 03:23 PM
11/16/17 03:23 PM
I wouldn't grind on the shaft tsk
Re: MSD distributor taking timing out [Re: mopar dave] #2404560
11/16/17 06:06 PM
11/16/17 06:06 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Hmmm,
I recently pulled my MSD billet distributor apart to do some maintenance on it after 10,000 or so miles and did indeed notice some play in the shaft. Took the dial indicator to it after I cleaned, changed advance bushing to a custom 16 degree bushing and installed new springs. The play was around .015. Assembled everything back together and up revved the engine and the timing advanced steadily to 36 degrees with no bouncing or retarding. Do you know how much play you have?
Re: MSD distributor taking timing out [Re: ccdave] #2404565
11/16/17 06:17 PM
11/16/17 06:17 PM
Mt Morris Michigan
Mt Morris Michigan
Cab, thanks. Didnt really want to grind on it anyhow. No, but not much. Took it out of the box locked timing and installed. I picked up 3 collars. 3/8 7/16 and 1/2. I dont believe the msd has a 1/2" shaft, but i should have it covered with 1 of the 3. Robbed a tap from my dad so im golden. Thanks guys
Re: MSD distributor taking timing out [Re: mopar dave] #2405987
11/19/17 05:04 PM
11/19/17 05:04 PM
Mt Morris Michigan
Mt Morris Michigan
Worked on installing the dist collar today. First tried installing it with no extra clearance, just tight. still had 2* retard with rpm, so took dist back out and set with about .010" clearance between the collar and gear and I tightened up the reluctor wheel gap to .010" as well. Put back together and same 3* retard with initial rpm. I'm thinking my cam is moving. I did not use a button on that when I installed it. so add a button or a crank trigger. crank trigger is easier.
Re: MSD distributor taking timing out [Re: mopar dave] #2405988
11/19/17 05:09 PM
11/19/17 05:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
How much slop in the intermediate gear and the tang on the end of the shaft..........I had mine brazed thicker than stock then hand ground it till it fit tight in the gear.......... beer
Re: MSD distributor taking timing out [Re: mopar dave] #2405993
11/19/17 05:19 PM
11/19/17 05:19 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I hope you are not seeing the Multiple spark function of the MSD.
Re: MSD distributor taking timing out [Re: FastmOp] #2405995
11/19/17 05:31 PM
11/19/17 05:31 PM
Mt Morris Michigan
Mt Morris Michigan
I use ice ignition. .006 in the dist shaft and about .010 between collar and gear. With no clearance at all i had 2* retard. Something else is going on here.
Re: MSD distributor taking timing out [Re: mopar dave] #2405997
11/19/17 05:42 PM
11/19/17 05:42 PM
Mt Morris Michigan
Mt Morris Michigan
Again, i had a firecore distributor before this msd and the firecore was rock steady with the timing. What could be different between the two that one has steady timing and the other pulls timing at rpm?
Re: MSD distributor taking timing out [Re: mopar dave] #2406000
11/19/17 05:52 PM
11/19/17 05:52 PM
Washington
madscientist Offline
Washington
So it's an ICE ignition and MSD distributor? Doesn't ICE make a distributor?
For most of my life I used a magneto because I hate electronic stuff.
I'm not a fan of mix and match stuff.
Re: MSD distributor taking timing out [Re: madscientist] #2406005
11/19/17 06:06 PM
11/19/17 06:06 PM
Mt Morris Michigan
Mt Morris Michigan
Yes. Mag pick up on both. Ice dist are not mag pick up and cost about $400.
Re: MSD distributor taking timing out [Re: mopar dave] #2406146
11/20/17 12:04 AM
11/20/17 12:04 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
If the firecore distributor was rock steady why did you change it to an MSD?
Page 3 of 3 1 2 3
