Re: Power to Manual steering adapters, what are my options?
[Re: itali83]
#240426
03/02/09 02:26 PM
03/02/09 02:26 PM
Posts: 1,075 United States
STLDuster
United States
I bought one from mancini last year, along with a Mancini 20:1 Worm gear. They really didn't fit together and I actually regret buying it. It was a major pain; I wish I would have bought a Firm Feel Adapter.
"No great genius has ever existed without some touch of madness." - Aristotle
[Re: topside]
#240428
03/02/09 06:11 PM
03/02/09 06:11 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
For 200 bucks I'd be changing the column!
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: itali83]
#240431
03/02/09 09:18 PM
03/02/09 09:18 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Go to the junkyard and get one out of a B-van. I know theres actually one sitting down at my local u-pull-it yard
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: itali83]
#240432
03/02/09 09:37 PM
03/02/09 09:37 PM
Posts: 2,648 USA
max
super gas
super gas
USA
several years ago i went the other direction from manual to power on my 70 Challenger.
my father and i took the column out and then on the bench we took the shaft out of the column and there was a couple of crash pins that we knocked out. slid the shaft up to the next set of holes and put another set of pins back in.
so in reality the stock shaft was used for both manual and power steering set ups.
You know, now that you say that, I have the column completely apart. And I see the the shaft is in two pieces and has what looks like white plastic, nylon maybe, that is holding the two halves together and I was wondering what that was for. So the column will collaps in the unfortunite event of a head on collision? So you are saying that the two halves of the steering shaft are the same, just bonded together in different places depending on the steering box? I'd like to go that route if possible and safe.
it has been a good while since we did that but i believe they were nylon and yes they are there in case of a head on collision so the shaft will collapes.
i don't know if every column is the same but i'm thinking the one in my Challenger had 2 sets of holes and we just slid the shaft to the upper set of holes and repined it.
i just don't remember right off hand what we used to repin the shaft.
[Re: Classof70Chally]
#240435
03/02/09 11:51 PM
03/02/09 11:51 PM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
I just did this conversion to my 71 Charger. YOu will seperate the shafts approximatley 3.5" apart.You dont have to put any nylon screws back in at all,it should be tight enough.Remember,you had to BEAT them apart,atleast 9 times out of 10.For piece of mind,scratch it up and put some JB Weld on it,it will still collapse. If I did it again,I would extend it 3 3/4"(same length as the adaptors),if it is too long,you can beat it back in. If you are too short,you gotta take ALL back apart and do it again. 3.5" on the heavy side(meaning a tad longer)will have you safely down into the coupler. Make sure you have the coupler for the manual box,as they are different,also put your pin back in the coupler to keep the shaft from coming out,(like it's going to anyway,not!).Here is a pic,you can see by the surface rust how much I brought it out. Good luck!
'71 383HP FJ6 Charger SE
[Re: IMGTX]
#240438
03/03/09 03:30 AM
03/03/09 03:30 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
You would end up with about half of what you start with. I see your points,but I dont see how it would'nt collapse like a manual column rod would. The manual rod is only that much longer. I also see what you mean about the length differences model to model,I did my 70 Dart a few years back and it was of course shorter than the one in the Charger I just did. I considered welding a piece in,but felt better going this route,20 years ago maybe... Those adaptors are just outrageous cash.Even the van ones anymore,if you find them.
[Re: 71 FJ6 Charger]
#240439
03/03/09 07:45 AM
03/03/09 07:45 AM
Posts: 169 Maine
itali83
Maine
Thanks guys, I'm defintly going to look at everything and make a decision on safety. I'm doing a ground up restoration and another 200 bucks is nothing in the big scheme of things, but if I can make it safe for less, I'm defintly going to go that route. What is this van adapter people are talking about? I'm not familliar with this. Thanks again!
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
[Re: itali83]
#240440
03/03/09 09:40 AM
03/03/09 09:40 AM
I think with the van adaptor the coupler from a manual steer colum is still needed.
