VALVE SPRING TESTER #2403799
11/15/17 12:47 AM
11/15/17 12:47 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
NEED A RECOMMENDATION FOR ON ENGINE VALVE SPRING TESTER. I HAVE A 440 WITH STAGE 6 HEADS.
Re: VALVE SPRING TESTER [Re: rickb67] #2403807
11/15/17 01:16 AM
11/15/17 01:16 AM
Me too, I don't do enough to warrant a Rimac so I was wondering about the accuracy of those mini ones that you compress in a vise.
Re: VALVE SPRING TESTER [Re: rickb67] #2403817
11/15/17 01:52 AM
11/15/17 01:52 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
These guys make great stuff!
Re: VALVE SPRING TESTER [Re: rickb67] #2403944
11/15/17 01:16 PM
11/15/17 01:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
For on the head stuff LSM is a great piece. As for bench top testing, the compressables that are sold through various outlets are fairly accurate compared to out LSM Benchtop and comparable to the Rimac we use. We used to keep one of those small compressable ones in the trailer for the track before getting the LSM one..
Re: VALVE SPRING TESTER [Re: rickb67] #2403945
11/15/17 01:17 PM
11/15/17 01:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You might look at this one if you are looking for a more affordable bench top unit. We use this one in the trailer..
http://lsmproducts.com/lsm_products/bench_top_valve_spring_testers
Re: VALVE SPRING TESTER [Re: rickb67] #2403994
11/15/17 03:16 PM
11/15/17 03:16 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
LSM products are great!
Bill
Re: VALVE SPRING TESTER [Re: rickb67] #2404223
11/15/17 09:59 PM
11/15/17 09:59 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
LSM! By far the best tools.
Re: VALVE SPRING TESTER [Re: Biginchmopar] #2404378
11/16/17 03:43 AM
11/16/17 03:43 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
NEED TO USE WITH THE HEAD ON THE ENGINE
Re: VALVE SPRING TESTER [Re: rickb67] #2404383
11/16/17 04:05 AM
11/16/17 04:05 AM
Cab_Burge Online work
Cab_Burge  Online Work
LSM sells those also, not sure if they make them for shaft type mopars heads or not confused scope
Re: VALVE SPRING TESTER [Re: Cab_Burge] #2404391
11/16/17 05:25 AM
11/16/17 05:25 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Their device rolls on top of the rocker near the valve and hooks under the rocker at the adjuster. Super simple. The tool has instructions for adjustments to make them work on different rockers. The instructions say to adjust the tool to match bench testing but that isn't necessary as all we are usually looking for, on the head, are weak differences. Tool works on my single shaft, T&D's and Harland Sharp rockers. You could probably make something flat to get them to work on stock rockers.
Re: VALVE SPRING TESTER [Re: rickb67] #2404445
11/16/17 12:29 PM
11/16/17 12:29 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I think they can be configured to fit most anything...
http://www.lsmproducts.com/lsm_products/valve_spring_pressure_testers
Re: VALVE SPRING TESTER [Re: rickb67] #2404528
11/16/17 04:16 PM
11/16/17 04:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
They sell on head stuff as well. IMO the best one out there..Well next to the Buxton stuff which is spendy and not as much coverage.
Re: VALVE SPRING TESTER [Re: Dave Hall] #2404847
11/17/17 06:32 AM
11/17/17 06:32 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Has anyone used the unit that Buxton engineering makes and sell?
Alan Jones
Re: VALVE SPRING TESTER [Re: rickb67] #2404848
11/17/17 06:43 AM
11/17/17 06:43 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
One of the guys on my crew has the on the head tester. Problem is, different operators get different results. We tried it a few times but if 3 people do the check, we get 3 different results. I now use a old school bench unit, can't remember the brand but it has a definite stop so every reading is the same, regardless of who operates the lever.
Re: VALVE SPRING TESTER [Re: rebel] #2405227
11/17/17 11:33 PM
11/17/17 11:33 PM
LA360 Offline
LA360  Offline
I noticed that on the LSM unit. Spend some time with those on your crew that will use it, you should be able to develop a method where you all get similar results.
Alan Jones
Re: VALVE SPRING TESTER [Re: LA360] #2405228
11/17/17 11:36 PM
11/17/17 11:36 PM
LA360 Offline
LA360  Offline
Alan Jones
Re: VALVE SPRING TESTER [Re: rickb67] #2405284
11/18/17 01:54 AM
11/18/17 01:54 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You can get three different results yourself just placing your hand differently or pulling differently. They just need to have some consistency in using the tool. The Buxton stuff is the cats tit$ really. IF it will work with what set up you are using..Wouldnt work on my B1 stuff really at all. But as with all mopars offsets it takes some patience and practice using any of them.
Re: VALVE SPRING TESTER [Re: Al_Alguire] #2406162
11/20/17 12:31 AM
11/20/17 12:31 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
THANK YOU
