Lean burn rewire #2403265
11/13/17 10:26 PM
11/13/17 10:26 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
The older electronic ignition retro fit kits had a diagram for eliminating factory "lean burn" systems. Does anybody have the diagram for this wiring? My son is going to get rid of the lean burn system on the new to him Mirada. What needs changing besides the ignition and carb?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Lean burn rewire [Re: rattler] #2403296
11/13/17 11:47 PM
11/13/17 11:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I did a butt load of these conversions, so many I hardly ever looked at the wiring diagram in the later years, but that was a long time ago.
Seems to me I pulled the IGN hot wire out of the Lean Burn harness (blue wire) and connected that to the IGN hot on the electronic conversion. I seldom did anything with the remaining Lean Burn harness except unplug it from the computer and tucked the end of it out of the way.
You will probably want a different air cleaner assembly as well, but the Lean Burn computer can be removed from the original air cleaner assembly, or the computer can just ride along. Gene
