MSD distributor taking timing out
#2403085
11/13/17 04:19 PM
11/13/17 04:19 PM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I have the same issue with my MSD distributor in the 511 that i had with the 408. When i rev the engine 3-4* timing comes out or retards. I fixed the SB issue by adding a crank trigger. Don't want to spend any more money right now and i think i might know why these distributors have this issue. Its not uncommon, just look it up. I believe the oil pump shaft gear is lifting when engine is rev'ed and turning as it lifts causing the timing to retard a bit. How can i stop the oil pump shaft from lifting? Thanks
Re: MSD distributor taking timing out
[Re: mopar dave]
#2403125
11/13/17 05:32 PM
11/13/17 05:32 PM
RapidRobert
I would drive out the roll pin & add some flat (non beveled) shims to reduce the axial play to .005" & you may need to in addition add the collar but first lightly twist the rotor back & forth with the dist still installed, not enough to get into the springs & see how much rotational play you have right now (you want very near none). speedway motors has a kit for $10. this may not be the issue for this situation but it is good to address it (it mainly causes spark scatter when timing it on the dampener) & a sloppy timing chain will do the same thing & a sloppy chain will skew cam degreeing readings.
[Re: mopar dave]
#2403131
11/13/17 05:44 PM
11/13/17 05:44 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Someone (Mopar Performance?) sold a shim kit for on the shaft to move it up and minimize end play between the two. I would think timing chain slack, cam twist, timing light electronics not keeping up, etc., would all contribute to this. They all bounce to some degree. All reasons for using a crank trigger.
[Re: mopar dave]
#2403326
11/14/17 12:34 AM
11/14/17 12:34 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I think they commonly shim the shaft up to reduce the play between the shaft and the distributor. Adding material to the tang of the distributor shaft and then machining or grinding it up to proper length is another option. Either way, it would have to be tuned with the intake or oil pump off to accurately adjust the end play without having it bind.
[Re: mopar dave]
#2403371
11/14/17 02:18 AM
11/14/17 02:18 AM
RapidRobert
set the collar on the end of the shaft reasonably snug then install the dist which will push it up then pull the dist & loctite the setscrew with the collar located at the height that it gets pushed up to.
[Re: mopar dave]
#2403592
11/14/17 05:31 PM
11/14/17 05:31 PM
BradH
So the collar fits on the end of the distributor shaft? Any idea how much clearance is needed? IIRC, the instructions with the collar I bought from Hughes said .006 or .008... not much!
[Re: mopar dave]
#2403616
11/14/17 06:40 PM
11/14/17 06:40 PM
Posts: 4,457 Washington
madscientist
Washington
Ok. Was gonna see if i could find one at the bolt store. Think ill just order one from Hughes. Any good hardware store will have what you need for less money.
[Re: mopar dave]
#2403639
11/14/17 07:19 PM
11/14/17 07:19 PM
madscientist
Washington
What size is the msd distributor shaft? I think...going by my used up memory...the shaft should measure .485-.490 so a set collar with a 1/2 hole will work. Forgot to mention they usually only have one set screw. I put two more in the collar so I have three. I'm just chicken like that.
[Re: mopar dave]
#2403968
11/15/17 02:20 PM
11/15/17 02:20 PM
Thumperdart
State of confusion
Ill see if i can find a collar that fits snug on the shaft. Thanks I shimmed mine years ago to have .002-.003 up n down movement and added a rubber/nylon bushing instead of the collar and it compresses nicely when the lock down is tightened. I also added a new bronze gear and had Pettis machine the difference off the gear to add a 3-piece torrington bearing deal and the timing is more stable than ever..........The bronze bushing and gear don't seem to play well together and wear quickly.........
[Re: mopar dave]
#2403989
11/15/17 03:05 PM
11/15/17 03:05 PM
madscientist
Washington
Ok thanks Dom. Ill see if i can find something in nylon instead of metal. Dom has a good point about taking the play out of the distributor shaft as well. I always do it, just forgot to mention it. If you do both your timing will be rock steady.
[Re: mopar dave]
#2404072
11/15/17 05:57 PM
11/15/17 05:57 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Go to Tractor Supply and get a 1/2" collar for $1.25...unless you just like paying $20+ for the same part. I've had one in my hemi for probably 5 years now. Fixed the same issue you're having.
[Re: mopar dave]
#2404127
11/15/17 07:13 PM
11/15/17 07:13 PM
an8sec70cuda
IIRC it fit pretty good. Like I said, been in there for around 5 years...no trouble. Must be good.
[Re: mopar dave]
#2404133
11/15/17 07:20 PM
11/15/17 07:20 PM
madscientist
Washington
Does the tsc collar fit the shaft snug? They don't have to fit real tight. Like I said...I'm a chicken so I add two more set screws. I've never had one come loose and I've done probably 40 of them over the years.
[Re: mopar dave]
#2404149
11/15/17 07:47 PM
11/15/17 07:47 PM
madscientist
Washington
Ok. Then ill just go to tsc then. I may already have one. Just have to go thru my nuts and bolts can. Second thought, ill go to tsc. Its quicker. I've spent hours looking for a bolt I could have run to town and bought. Someday I'll organize that stuff better.
[Re: mopar dave]
#2404226
11/15/17 10:02 PM
11/15/17 10:02 PM
Posts: 326 Alberta
Wookie316
Alberta
Anyone have a a reference photo they can post? I am pretty sure I understand but a Photo would be great. Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: mopar dave]
#2406000
11/19/17 05:52 PM
11/19/17 05:52 PM
madscientist
Washington
So it's an ICE ignition and MSD distributor? Doesn't ICE make a distributor?
For most of my life I used a magneto because I hate electronic stuff.
I'm not a fan of mix and match stuff.
