Re: KB alum block What head gasket?
[Re: RATTRAP]
#2403012
11/13/17 02:05 PM
11/13/17 02:05 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
KB alum block What head gasket is everyone using PN if possible? Its not that easy with the info you gave. NA or power-adder, bore size, quench, desired compression. After you figure out the thickness you want you could call the guy in this link. I think he recommends .030 over bore size and you should have them in your hand in 4-7 days. http://www.4secondsflat.com/Cometic-MLS_Gaskets.html
[Re: RATTRAP]
#2403014
11/13/17 02:07 PM
11/13/17 02:07 PM
Posts: 31,074 Oregon
AndyF
KB alum block What head gasket is everyone using PN if possible? Um, how would we know? Wouldn't we need to know the bore size and if it is a Hemi or a wedge and maybe the compression ratio and some stuff like that?
[Re: RATTRAP]
#2403042
11/13/17 03:07 PM
11/13/17 03:07 PM
Posts: 1,505 TN
SCATPACK 1
TN
We Always used solid copper. I have found Copper to be more forgiving in regards to the deck/surface finish and it can be reused if necessary. As stated above, you will need to know your cylinder bore and engine type, wedge or Hemi.
Old Geezer Racing
[Re: RATTRAP]
#2403103
11/13/17 04:46 PM
11/13/17 04:46 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
KB hemis move the steam holes out away from the bore. You can get cometic from KB and they may be an exclusive that you can't get direct from cometic. I would call Tim Banning or Ray Barton.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: Mopar_Rich]
#2403174
11/13/17 07:30 PM
11/13/17 07:30 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
Cool. Mine was a custom. They must have come up with a production number The SPM in the PN# means Special Mopar & the 040 is the thickness. not sure of the other numbers in the PN number.
