Re: Street/Strip Combos
[Re: A/MP]
#2402962
11/13/17 12:36 PM
11/13/17 12:36 PM
Posts: 4,679 Wichita
GY3
Wichita
Lets use 4 rather plentiful motors- 318, 360, 383 and 440. Keeping it simple, all A-B body styles with average weight of 3500 lbs. Allowing for a 904/727 trans(comes with the car), 8 3/4/Dana 60( comes with), lets get some suggestions for complete motor and converter combo. Keep the rear gear at 4.10 or smaller(numerically). Tracks have or are flirting with 12.50 and 11.50 index racing, so let pick an index and see what combos are doable. Combo should be able to live for 3 years and N/A. Let's keep the total budget under 7K. I had plenty of suggestions...until you mentioned $7k.
[Re: A/MP]
#2402998
11/13/17 01:46 PM
11/13/17 01:46 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Flat top 440, e street heads, .550 solid cam, rpm intake, 850/950 carb, 1-7/8 headers....... 525-ish hp.
In any 1/2 way decent B body under 3700lbs race weight with a decent converter, 4.10's and good tires....... That's 11's all day long.
For an A body I'd do a 408/416, the new TF heads, victor intake, QFT "850" carb, .550-.570 solid cam, 9.5 converter.
Doing them for 7k, you'd be doing plenty of it yourself.
You plan the build, it just costs what it costs.
[Re: A/MP]
#2403056
11/13/17 03:33 PM
11/13/17 03:33 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
My combo fits this bill. Engine was built for under 6k, throw in another grand for a basic 727 with a decent converter, and you basically have my setup. If aesthetics weren't important, you certainly could start cutting weight out of the car and I'm sure you could get it down near the 10's, if not into. My tubby street car packs 3800+ lbs down the track though.
Basics: 400 / 451; crank and block sourced off of Craigslist cheap. Block decked for "zero" & align honed Scat Rods Iconn pistons (flat with 5cc valve reliefs - 10.5:1 at zero deck) 440source stealth heads - no work / OTB, other than swapped locks retainers and springs. Engle Solid flat tappet can - 252* / .573; square on 109 cl. RPM intake with 4150 carb (currently a 1000cfm annular HP Holley) MSD digital 6+ box, with Mallory elec. dizzy. (Digital box gives me a 2-step and high-end limiter) Hooker Comp Headers 727 w/ T/A valve body Lupo Dynamic converter - custom built 9-1/2" 4.10 gears on a spool in an 8-3/4"
I like the 451 over the 440 for a couple of reasons: lighter rotating assembly helps make power AND lives longer. Low deck block is lighter, fits better in the car. Maximum bore helps the same heads breath just a little better.
There's probably a dozen different ways to skin the OP's cat, but this one works for me.
[Re: fast68plymouth]
#2403062
11/13/17 03:47 PM
11/13/17 03:47 PM
GY3
Wichita
You plan the build, it just costs what it costs. I did the B-body combo that he listed but bumped up the cubes to 505 since I needed a crank anyway. I built the entire drivetrain myself save for block machining and narrowing of the Dana. I have $7500 just in the engine and that is starting with an $80 block! You could probably knock $1000-$1500 off if you didn't do cnc porting or roller cam. Overall, it makes for a very reliable, fast combo that doesn't require expensive fuel.
[Re: A/MP]
#2403074
11/13/17 04:11 PM
11/13/17 04:11 PM
Posts: 10,001 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A body, 5.9 magnum using a crosswind intake, reground cam, stock valve train, .030 stock weight replacement pistons, use la water pump etc. La distributer. Back cut intake valves, bowl port. 2800 stall 11 inch converter (cheap!) Used carb, 1 5/8 headers.
[Re: A/MP]
#2403088
11/13/17 04:24 PM
11/13/17 04:24 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
For an A-body. I'm expecting high 11's in 100% street trim with a 3.23 gear and 10" converter, stock stroke OE crank.
These prices reflect retail over the counter, of which many times we don't have to pay, right? Swap meets, classified ads, ebay, etc...
[Re: A/MP]
#2403167
11/13/17 07:08 PM
11/13/17 07:08 PM
cudadoug
Is there something specific on how to build that motor(heads,cam,intake carb)to give the converter builder something to work with if you are using a BB with 3.55 gear. Can you get the same with a SB with a 3.55? I build as I want it, and have a good converter guy that can match a converter to the combo and my goals. I'm sure most reputable converter guys, (Lupo, Ultimate, T/A) can get the most out of any combo for your specific goals.
#2403196
11/13/17 08:17 PM
11/13/17 08:17 PM
BradH
You plan the build, it just costs what it costs. Yeah, even my best budget projections for my last few builds have been "blowed up" by the reality of all the other stuff that I didn't anticipate needing or happening, or parts and/or labor costs that were simply more expensive than I'd expected.
[Re: BradH]
#2403211
11/13/17 08:39 PM
11/13/17 08:39 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I know how cheap I could build but a big block or small block to go the times listed. My preference for this build would start with a 360 block for budget and ease of working and fitting in the engine bay. My Sons 360 just went 6.54 (approximate 10.30's 1/4 mile) with a .030 over 360, flat-top pistons, a used 120 dollar roller cam, and ported Edelbrock heads. He had an issue at Norwalk (Sunday night) and pulled the head, sent it out, and it was back running on Wednesday. Not a cakewalk on an A body but sure easier than a big block in one.
[Re: A/MP]
#2403244
11/13/17 09:38 PM
11/13/17 09:38 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
383 block/turned down 440 crank, RPM heads (untouched), RPM intake, ross flat tops, manley rods, solid ft (porter racing heads spec), 373 gears, tko transmission, holley 830 11.60s to 70s (66 belv vert 3950 lbs)
same engine, new cam (dwayne PRH) specd, heads ported by PRH, beehive springs, still schubecks, 4.10 gears, jerico trans, best 11.09, normally 11.20s
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: A/MP]
#2403259
11/13/17 10:17 PM
11/13/17 10:17 PM
Posts: 9,839 MI, usa
dvw
MI, usa
Buddy's 65 Belvedere (totally stock, full interior no bar or frame connectors). 8 3/4 4.10, 9x28 slick, good converter. 440+.030, stock rods with new bolts, Speed pro heavy pistons, 10-1 measured, used Eddy RPM's, Mopar .557 solid, aluminum rockers, 1 3/4 headers. It uses a low rise Weiand 2x4 with 2 600 Eddys. My bet is a Performer RPM and 850 Holley would be quicker. 11.30's@117. it's gone hundreds of passes with next to no maintenance. Runs on pump 93 Doug
[Re: A/MP]
#2403354
11/14/17 01:20 AM
11/14/17 01:20 AM
Posts: 198 Gainesville Fl
mphsmitch
Gainesville Fl
90 Dakota 3500 lbs with driver 408 cid Magnum R/T heads Air Gap intake HP 750 UltraDyne .242/.248 @ .050 .600 lift 10.3 compression 727 w/ manual v/b 9.5" 4600 stall converter 3.73 gears 275 Pro drag radials 11.09 @ 120 mph in good air
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
[Re: A/MP]
#2403357
11/14/17 01:28 AM
11/14/17 01:28 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
My 67 Belvedere has a 3.55 geared 8 3/4, with a tight 10 inch converter that only stalls about 2700. 1 3/4 headers with 2 1/2 inch exhaust out the back. Raced and driven on the same 255/60/15 MT Drag Radials.
The 440 features old school TRW flat tops on stock rods. The block and crank are stock, but feature studs in both the mains and heads. I use the modern ported stealth heads with the as supplied valve springs because it only has the old Comp magnum hyd. 270/470 cam. Since the cam is so small, I just re-used the stock rockers and pushrods (definitely helps with the budget). Cometic head gaskets, M-1 intake with 750 double pumper. 440 source 7 qt pan and pick-up with a melling HV pump. MP electronic distributor fired by an MSD digital 6.
The car will run 12.50s at 107-8 NA. I've done quite a bit of 11.50 index racing with it because I have a big shot plate on it( reason for the cometic gaskets). Best on the bottle is 11.31-122.5
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
