por-15 #2402715
11/12/17 09:17 PM
11/12/17 09:17 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
https://www.summitracing.com/parts/poi-45208/overview/
Anyone use this stuff?
your thoughts?..........Thaxs wave
Re: por-15 [Re: racerx] #2402719
11/12/17 09:23 PM
11/12/17 09:23 PM
Kirkland, Washington
Pacnorthcuda Offline
I've had good luck with it but there are a LOT of people that hate the stuff.
Works best on pretty crusty substrates.
Re: por-15 [Re: Pacnorthcuda] #2402748
11/12/17 10:11 PM
11/12/17 10:11 PM
IN
ahy Offline
ahy  Offline
IN
I have never used it. I have used Eastwood "Rust Encapsulator" primer with good results. Also red Rustoleum primer. Key with any of these is to get any grease off and also get any loose paint or loose corrosion cleaned before application.
Re: por-15 [Re: racerx] #2402780
11/12/17 11:11 PM
11/12/17 11:11 PM
I've used it, I have several cans of the gloss and semi gloss as well as the grey up
It stops the rust but if it is exposed to sunlight it needs a top coat of paint to protect it from the U.V and infra red rays shruggy
I've used it on the rear end housings and floors so far with no complaints or problems up
Re: por-15 [Re: racerx] #2402817
11/12/17 11:57 PM
11/12/17 11:57 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
How long has it last, wondering if this stuff breaks down over years and allow moister to enter causing rust over a period of time......Thax for the response up
Re: por-15 [Re: racerx] #2402821
11/13/17 12:05 AM
11/13/17 12:05 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Just don`t get it on the skin. It is really hard to get off.
Re: por-15 [Re: racerx] #2402822
11/13/17 12:05 AM
11/13/17 12:05 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Be sure to time your, 'needs', so you don't need to go 'need' while por-15ing on your car, and so not on your hootus. eek
http://www.explorerforum.com/forums/inde...y-hootus.18595/
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: por-15 [Re: racerx] #2402829
11/13/17 12:23 AM
11/13/17 12:23 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Its a very tough epoxy paint. We tried using in the blind locations (inside quarters). Didn't hold up in that (mis)use. No paint will because the surface can't be prepped properly. If there is rust, use their rusty metal primer. Rustoleum rusty metal primer should be compatible, but that will be your risk if you want to try it instead.
Re: por-15 [Re: racerx] #2402839
11/13/17 12:35 AM
11/13/17 12:35 AM
The biggest complaints I recall are people saying it pealed off. I would recomend only using on surfaces with a lot of mechanical tooth.
Re: por-15 [Re: racerx] #2402848
11/13/17 12:58 AM
11/13/17 12:58 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Too thick it will peel. Clean surface it will peel. Not for me.......
Re: por-15 [Re: racerx] #2402867
11/13/17 01:42 AM
11/13/17 01:42 AM
Long Island, NY
shocktrp Offline
shocktrp  Offline
Long Island, NY
I've used it with no problems.
Don't get it on your skin (or anything else) because it doesn't come off.
Re: por-15 [Re: racerx] #2402899
11/13/17 04:23 AM
11/13/17 04:23 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Let me start out saying I believed it in a lot. I personally have used several gallons of the stuff before.
I put some on both sides a pair of sandblasted box sides that spent the winter in my heated, dry garage. Both box sides had rust showing through the POR 15 the next spring. The rust was under the POR covering and it wasn't flaking off or anything. I have bare sheet metal in my garage that didn't have that much rust on it after being in the same garage for more then 10 years.
I've had some on the bottom of my 77 Dodge truck cab the peeled off in sheets. I've had some that was still stuck to the metal so well it couldn't scratch off but the metal under the paint was rotted away. Then there is the back of the sheet metal sign in my yard. I spread some POR on the back side of it that was left over from something I was covering with it. The sign was unprepared, I simply POR on the sign back. 3-4 years later, the black POR was starting to fade, so I had some paint left over from painting a truck and emptied the spray gun on the sign back (didn't even wipe the dirt off). 10 years latter, the back of that sign looks great!
The deal with the box sides was the final straw for POR for me. When it couldn't even protect sandblasted sheet metal inside my shop for 3 months, I quit using it. Gene
Re: por-15 [Re: racerx] #2402910
11/13/17 08:12 AM
11/13/17 08:12 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs for the info. Gents upcan bondo be applied over this stuff?
Re: por-15 [Re: Mattax] #2402911
11/13/17 08:19 AM
11/13/17 08:19 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs for the heads-up up cause that's one of the spots I was wanting to use this stuff (inner cab quarters)I'll checkout there primers. wave
Re: por-15 [Re: racerx] #2402924
11/13/17 10:46 AM
11/13/17 10:46 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We use it inside of doors, 1/4s, cowls etc. It hardens like concrete. Use a hand pump sprayer and and let run out the openings. Make sure the area under the car is covered cause when it drips on the concrete it's never coming off. It does not like clean shiny metal.
Doug
Re: por-15 [Re: racerx] #2402932
11/13/17 11:37 AM
11/13/17 11:37 AM
McCandlessboy Offline
We had it on a lot of stuff, a lot of it pealed. We're using lizard skin now
Re: por-15 [Re: racerx] #2402950
11/13/17 12:01 PM
11/13/17 12:01 PM
Minn
SportF Offline
SportF  Offline
Minn
It says you can paint over rust. It should say, "you have to paint over rust" Get it on anything else and it seems to come off.
Try Ospho
ttps://www.ebay.com/itm/Ospho-605-Metal-Treatment/322607362234?_trkparms=aid%3D555019%26algo%3DPL.BANDIT%26ao%3D1%26asc%3D41375%26meid%3D49e45d4f138447d0bf32ba4795171807%26pid%3D100505%26rk%3D1%26rkt%3D1%26&_trksid=p2045573.c100505.m3226
This doesn't put a heavy coat on anything and is made to paint over. I haven't used it long enough to give it a "time" test, but when you read the chemical uses of this stuff, it seems like it is a better answer.
Re: por-15 [Re: racerx] #2402954
11/13/17 12:19 PM
11/13/17 12:19 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Cab corners should be OK as I would think you can see everything.
If it's a blind or a location it can't be applied properly, pouring it in doesn't work. As other people have mentioned, the rust continues to grow. For blind hidden corners, something like Waxoil is better approach.
Two paints that are pretty effective over rust are Corroless (you'll have to get it from UK) and Hammerite. Corroless is a primer but its highly resistant to moisture permeating through it. It was imported by Eastwood until they started selling their own label 'encapsulator' - they initially claimed it was the same. It's not. Not even related. Hammerite is available here and the formula appears to be the same as UK.
Re: por-15 [Re: McCandlessboy] #2403851
11/15/17 04:01 AM
11/15/17 04:01 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I used a bunch of it years ago and did not have a good experience. Purchased all the expensive prep stuff and the paint and followed the directions. Last year I used a hand scraper and scraped a bunch off that had rust bubbles forming underneath it. Ironically, stuff that I painted around the same time using a cheap rattle can has held up better.
In my opinion this stuff does not live up to the hype and is not worth the price. When it does stick, it is difficult to remove. Therefore, I'd rather use a regular paint that will likely hold up better and will be easier to remove later if I want to freshen a part up.
Re: por-15 [Re: racerx] #2403916
11/15/17 12:25 PM
11/15/17 12:25 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
It's garbage. I bought into the hype and bought all their expensive prep products before I knew any better. I applied it on cleaned, scuffed and prepped oem paint. I also applied it to lightly rusted steel that I cleaned and prepped as per POR's instructions. 6 months later most of it was gone like it had never been there, what was left was peeling off like when you pick glue or silicone off your hands. If you're intent on using it, save yourself a few steps and place your money straight into a garbage can.
Now I paint everything properly with a catalyzed epoxy primer. I have never seen the pros using crap in a can like POR, always the legit 2 part stuff.
