Re: Need valve lash help with a lunati camshaft
[Re: goldmember]
#240269
03/01/09 07:39 PM
03/01/09 07:39 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
0 lash plus 1/2 - 1 turn. Make sure that you set with the cam on the base circle and the plunger at the top of the travel not bottomed out.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: Pacnorthcuda]
#240271
03/01/09 07:53 PM
03/01/09 07:53 PM
Any Lunati hyd. cam that i installed and that would be 3 in the past 2 years ran "0" lash...
