Need valve lash help with a lunati camshaft #240265
03/01/09 07:22 PM
03/01/09 07:22 PM
Chi-Town
PlumCrazyCharger Offline OP
Chi-Town
Hey guys
I have a Lunati Hydralic Camshaft part no. 30306 and grind no. H235-245. This cam card does not have the lash numbers?? Can anyone help??
Cam specs:
Lift at valve @ 1.5 ratio
Int. .507
Exh. .534
Duration @ .050 235 int and 245 exh
Advertised Duration 285 int and 295 exh
lobe seperation 110
Thanks for the help!
Sean
Re: Need valve lash help with a lunati camshaft [Re: PlumCrazyCharger] #240266
03/01/09 07:28 PM
03/01/09 07:28 PM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
On a hyd cam I just preload the lifter down about .035 on the plunger
Re: Need valve lash help with a lunati camshaft [Re: PlumCrazyCharger] #240267
03/01/09 07:29 PM
03/01/09 07:29 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Uhh......if it's hydraulic it is 1/2 turn past 0. (IRON HEADS) 3/4 TO 1 turn past 0 on alum. heads.
I just put one of there voodoo cams in my street car and love it.
Re: Need valve lash help with a lunati camshaft [Re: PlumCrazyCharger] #240268
03/01/09 07:31 PM
03/01/09 07:31 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Hyd cams generally don't run "lash".
Re: Need valve lash help with a lunati camshaft [Re: goldmember] #240269
03/01/09 07:39 PM
03/01/09 07:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
0 lash plus 1/2 - 1 turn. Make sure that you set with the cam on the base circle and the plunger at the top of the travel not bottomed out.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Need valve lash help with a lunati camshaft [Re: goldmember] #240270
03/01/09 07:47 PM
03/01/09 07:47 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Yep...Pre load, not Lash
Re: Need valve lash help with a lunati camshaft [Re: Pacnorthcuda] #240271
03/01/09 07:53 PM
03/01/09 07:53 PM
Any Lunati hyd. cam that i installed and that would be 3 in the past 2 years ran "0" lash...
Re: Need valve lash help with a lunati camshaft #240272
03/01/09 08:03 PM
03/01/09 08:03 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
0 lash then 1/2 turn. when exh.valve is open, adjust intake(lifter will be on base circle of lobe) when intake goes past full lift and starts to close,adjust the exh( lifter will be on base circle of lobe. good luck.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: Need valve lash help with a lunati camshaft [Re: kingdust] #240273
03/01/09 08:46 PM
03/01/09 08:46 PM
Chi-Town
Chi-Town
Thanks! I'm such a dunce! Haven't had a hydralic cam in over 10 years and forgot that they need preload and no lash. Working with my big motors makes me forget about the smaller stuff.
Sean
