Middle cylinders on big block lean #240255
03/01/09 07:22 PM
03/01/09 07:22 PM
Mopar Lane,Mississippi
67HEMI Offline OP
67HEMI  Offline OP
Is there a carb spacer that will cure the leaner center cyliners on a big block? I have an Indy as cast intake,lil ez CNC 295 heads, with an out of the box dominator. I heard you could mount the carb turned at an angle to cure most of it.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Middle cylinders on big block lean [Re: 67HEMI] #240256
03/01/09 08:05 PM
03/01/09 08:05 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
you need to have that Indy intake manifold worked on. i had the same problem till my intake had its runners removed from out of the plenum. plugs all read the same now but before 1,2,7,&8 were rich.
Re: Middle cylinders on big block lean [Re: rebel] #240257
03/01/09 08:11 PM
03/01/09 08:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep, a set of EGT's mounted in exactly the same point
in the headers will help you big time in dialing in
a manifold
Re: Middle cylinders on big block lean [Re: MR_P_BODY] #240258
03/01/09 08:30 PM
03/01/09 08:30 PM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
i had the same problem, ported a little helped, but .044 nos jets in the fogger fixed it lol
Re: Middle cylinders on big block lean [Re: rtstreet] #240259
03/01/09 08:37 PM
03/01/09 08:37 PM
Indiana
maxie Offline
maxie  Offline
Indiana
When I was getting the hemi built, the guy that did it said the intake would need some work to prevent the problem you are having. I have a Indy 426-2 intake on it with a 1070 cfm carb. He didnt put any dams in it, just some and The only intake I have ever seen with a cocked mount carb was on a big block chevy. Do they make them for a mopar or a spacer that cocks them?
Re: Middle cylinders on big block lean [Re: maxie] #240260
03/01/09 10:15 PM
03/01/09 10:15 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
this really proves how bad ICH R&D work is. you'd think they could have sorted this problem before it went into production huh?
Re: Middle cylinders on big block lean [Re: rebel] #240261
03/02/09 11:04 PM
03/02/09 11:04 PM
67HEMI Offline OP
67HEMI  Offline OP
I called Nick at Compu-flow today and he said they could resolve most of it by porting on the intake and using a shear plate.
Re: Middle cylinders on big block lean [Re: rebel] #240262
03/02/09 11:05 PM
03/02/09 11:05 PM
67HEMI Offline OP
67HEMI  Offline OP
Especially if it is a common problem with a wedge.
