Will this 8.75 combo fit in my Duster? #2402519
11/12/17 02:38 PM
11/12/17 02:38 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I’m doing a fairly budget build/V8/4 speed swap on my 73 Duster. I believe I now have everything for the swap. Here’s what I have and what I’m hoping might work. Seeing as a stock A body 8.75 in a Duster leaves a good bit of room to the outter wheel well, maybe I’ll be lucky and this will fit. It would be nice since I have all this stuff from years of collecting. Thanks!!
68-70 B body 8.75
7” Police wheels
My perches are right at about 44”
It’s hard to measure with the chunk in... but from flange to flange (housing, not axle) measures 55 1/8. I’m positive it’s shorter than that because I had to bend the tape a hair to get to the other side.
Re: Will this 8.75 combo fit in my Duster? [Re: da50r] #2402524
11/12/17 02:47 PM
11/12/17 02:47 PM
for flange to flange you could take 2 pieces of dental floss with a small nut tied on each end & affix em to the flanges, hanging down to your bench then tape that distance between em but likely someone will have an answer for you on this fairly soon as I've seen it posted before.
Re: Will this 8.75 combo fit in my Duster? [Re: da50r] #2402525
11/12/17 02:48 PM
11/12/17 02:48 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I saved a thread from a while back but can’t seem to find it.
Re: Will this 8.75 combo fit in my Duster? [Re: RapidRobert] #2402529
11/12/17 02:52 PM
11/12/17 02:52 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I use a piece of new brake line and bend it so it matches where I need to measure. You can easily go around whatever might make it hard to measure with a tape.
Re: Will this 8.75 combo fit in my Duster? [Re: da50r] #2402531
11/12/17 02:53 PM
11/12/17 02:53 PM
The stock B body 8 3/4 rear ends are right at two inches wider than the same year A body are shruggy
Re: Will this 8.75 combo fit in my Duster? [Re: da50r] #2402563
11/12/17 03:32 PM
11/12/17 03:32 PM
IN
polaraholic Offline
polaraholic  Offline
IN
The chart I have shows your stock axle would be 51.4" flange to flange and 43" spring width. A b-body is 55" F to F and 44" spring width. Looks like you will need to change the drive shaft also.
Re: Will this 8.75 combo fit in my Duster? [Re: polaraholic] #2402595
11/12/17 04:27 PM
11/12/17 04:27 PM
CA
crackedback Offline
crackedback  Offline
CA
Please kill that chart, it's horrible and wrong on a bunch of measurements.
A much better reference...
http://www.moparts.org/Tech/Archive/axle/16.html
Stock 68-70 B should be 60.125ish wheel mount to wheel mount. 44" perches are 1" wider than an A at 43". Lots of people pull the springs to get B rears installed.
It may fit OK. Wheels tend to need a bit more backspace than the stock mopar wheels with a 68-70 B rear in an A body. Dusters are more forgiving than Darts.
Re: Will this 8.75 combo fit in my Duster? [Re: crackedback] #2402615
11/12/17 05:32 PM
11/12/17 05:32 PM
IN
polaraholic Offline
polaraholic  Offline
IN
Thanks for the new info. I just measured a housing I have and it didn't match anything on my chart. up
Re: Will this 8.75 combo fit in my Duster? [Re: da50r] #2402628
11/12/17 06:00 PM
11/12/17 06:00 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
The chart isn’t very accurate in some applications. I think I will be ok but it’ll be a little close. Thanks guys.
