Re: Jack Stand
[Re: ct440rod]
#2402448
11/12/17 01:08 PM
11/12/17 01:08 PM
Posts: 10,736 North Dakota
6PakBee
North Dakota
I like some kind of support so the car isn't sitting on the tires. But that's just me.
Re: Jack Stand
[Re: ct440rod]
#2402509
11/12/17 02:26 PM
11/12/17 02:26 PM
RapidRobert
should I put car on jack stands? absolutely yes
Re: Jack Stand
[Re: ct440rod]
#2402580
11/12/17 03:56 PM
11/12/17 03:56 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
I take mine off now and the car is on stands.But mine sits outside all winter under a cover.My rears do have some weather cracks from when I did not take them off and put them in the garage.Rocky
Chrysler Firepower
Re: Jack Stand
[Re: Alchemi]
#2402769
11/12/17 10:53 PM
11/12/17 10:53 PM
Posts: 31,050 Oregon
AndyF
What's wrong with resting the springs? Unibody cars should be supported by the suspension. If you put jackstands under the frame stubs then the ends of the car will bend down. You'll have fewer problems if you just support the car the way it is designed to be supported. Either leave the wheels and tires on or use hubstands in the front. In the rear you can put jackstands under the rear axle. As I said earlier, I don't bother pulling the wheels. Just fill the tires full of air and if you want to roll the car forward 6 inches once a month then do that.
Re: Jack Stand
[Re: AndyF]
#2402838
11/13/17 12:34 AM
11/13/17 12:34 AM
RapidRobert
My pref: stands under the axle & under the LCA's
