Page 1 of 3 1 2 3
727 Why you should always CHECK ! #2402114
11/11/17 08:25 PM
11/11/17 08:25 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
I broke the ring and pinion at Pittsburgh back in September right off the starting line. I pulled over and stopped before the 60ft timer, rev limiter set for 6800. As you can see it demolished the sprag, rolled the flanges and spit the springs out. I run an aluminium drum and bolt in sprag, but still a mess.
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402119
11/11/17 08:32 PM
11/11/17 08:32 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
And yes I drove into the trailer and out of the trailer with the broken ring pinion. After replacing the ring and pinion could have drove it, that's why I am saying you have to check after a rearend failure.
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402132
11/11/17 08:56 PM
11/11/17 08:56 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Message heard loud & clear.
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402133
11/11/17 08:56 PM
11/11/17 08:56 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Agree a zillion percent. I'm not a supporter of the "We're all gonna die if we race a torqueflite" crowd, but, this is common sense. Anytime the motor and drive train lose their load in 1st gear you gotta check. The trans will seem fine puttsying around....but it's not. I remember when that happened, Jim.....This was the instruction we were given in big bold letters back in the sixties, before the fancy stuff was available. Just common sense, paying attention.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402138
11/11/17 09:00 PM
11/11/17 09:00 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Good save! What caused the R&P failure?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402141
11/11/17 09:02 PM
11/11/17 09:02 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
This is the second rear end failure I have had and the first one did no damage to the transmission. As you can see the second one destroyed the sprag, I am looking at replacing the rear drum and rear support due to the damage done. You have to check each time, never know when.... it goes to sh$t
Re: 727 Why you should always CHECK ! [Re: Hemi_Joel] #2402145
11/11/17 09:05 PM
11/11/17 09:05 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
I am thinking how I set up the R&P, my first time and it lasted 6+ years.
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402174
11/11/17 10:00 PM
11/11/17 10:00 PM
P
Porter67 Offline
Porter67  Offline
P
Its the same with chevys as well, ive toasted 3 rears and turbo 400-s at the same time over the years.
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402180
11/11/17 10:04 PM
11/11/17 10:04 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
On a 727 to help out on the explosion what is needed steel front drum rear bolt in spray and what else will help out on the explosion
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402190
11/11/17 10:11 PM
11/11/17 10:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
the fact you run one of the "proper" drums may have saved you from finding out the REALLY hard way your sprag got lunched. You move on for another day of racing smile
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402218
11/11/17 10:42 PM
11/11/17 10:42 PM
Mo.
racerx Offline
racerx  Offline
Mo.
curios 9" or Dana work ?
Re: 727 Why you should always CHECK ! [Re: racerx] #2402225
11/11/17 10:51 PM
11/11/17 10:51 PM
Kirkland, Washington
Pacnorthcuda Offline
It's not a 9"
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402228
11/11/17 10:59 PM
11/11/17 10:59 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
D60
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402249
11/11/17 11:38 PM
11/11/17 11:38 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
bought the aluminium drum just for this reason. racerx Dana 60 rear end. The bolt in sprag saved my case or I'd be looking for new one.
Re: 727 Why you should always CHECK ! [Re: scottb] #2402253
11/11/17 11:41 PM
11/11/17 11:41 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
No explosion here =, inspected and will replace all damaged componets.
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402262
11/11/17 11:53 PM
11/11/17 11:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Do you coast it with the engine off at each event? That saved me. Could hear it clicking with the engine off coasting. When it was disassembled the gears looked perfect, fluid looked perfect, until a pattern check. Every 10th tooth had a hard wear pattern. Also had zero backlash (installed at .007"). It made it 425 passes (Dana 60 street gear).
Doug
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402284
11/12/17 12:38 AM
11/12/17 12:38 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Didn't Casey just do the same? work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402362
11/12/17 03:09 AM
11/12/17 03:09 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
would agree a good save,dont need this to happen to ya like it did me
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402370
11/12/17 03:42 AM
11/12/17 03:42 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
It's a weird feeling when you tear one down and find no damage to the sprag. On one hand, you're happy nothing was broken, but on the other hand you're like, "Dang it, I just did all that work for nothing!"
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: 727 Why you should always CHECK ! [Re: nss guy] #2402467
11/12/17 01:34 PM
11/12/17 01:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree to pull the trans and check it anytime a rear blows with the 727. My buddies 440 six pack Roadrunner broke some ring & pinion teeth some years back and after he had a shop fix it I remember when he drove it over my house he asked me to listen to the noise it was now making. Which was a scraping noise from the damaged sprag. Course he had to have it repaired. Ron
Page 1 of 3 1 2 3
