904 beef up; best source for all needed parts?
#2401811
11/11/17 11:29 AM
11/11/17 11:29 AM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
After some searches I find there are more than a couple of pitfalls in trying to upgrade a 1972 904 to five clutches, in order to handle the 408 I built. With 520 torque, I want to be sure The 904 will live a long life. I plan on using a full manual VB, and will take it to the track with slicks a few times. Who can steer me right and sell me all the right parts?
Re: 904 beef up; best source for all needed parts?
[Re: gregsdart]
#2401827
11/11/17 12:06 PM
11/11/17 12:06 PM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
what frictions are you using? think you can fit 5 if using the thin ones.
As far as parts... Pro Trans is right across the desert from me so I've been using their stuff here and there.
[Re: gregsdart]
#2401828
11/11/17 12:09 PM
11/11/17 12:09 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Greg, If you aren't bracket racing it every weekend, most of the stock pieces will do the job. 1. Run the thin clutches from low/reverse drum in the high gear drum 2. Multi-spring pack to replace the large wound spring in the high gear drum. 3. I went with the aftermarket front pump gear with the larger lugs to reduce the chance of breaking the converter snout, but I never broke one previously. 4. I added the 300M input shaft on my last upgrade, but I've never broken a stock one. 5. If using a RMVB, try turning up the line pressure a little. the biggest problem with the 904 is burning up the high gear clutches, so more clamping force helps.
I've ordered stuff from A&A, Cope, and TCS. All charge shipping, so try to know what you need and get it all in one order!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: gregsdart]
#2401850
11/11/17 12:42 PM
11/11/17 12:42 PM
Posts: 1,559 New Smyrna Beach FL
scottb
New Smyrna Beach FL
If you use the thinner cluthes and plates you can get five in a 4 plate drum or if you have a 5 you can get 6 in those and yes turn up the line pressure call Rick Allison at A&A I would also put in a 4,2 lever
[Re: scottb]
#2401857
11/11/17 12:49 PM
11/11/17 12:49 PM
Posts: 12,093 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Another vote for http://www.aandatrans.com/. They have helped me with 727s, 904s, and 518s. They have the parts AND the knowledge.
Master, again and still
[Re: gregsdart]
#2401887
11/11/17 01:46 PM
11/11/17 01:46 PM
gregsdart
Thanks, guys! And to think in 1985 I let an a999 equipped 360v8 1977 fury go to the bone yard! I could have used both motor and tranny!
[Re: gregsdart]
#2401900
11/11/17 02:05 PM
11/11/17 02:05 PM
Posts: 43,195 Bend,OR USA
Cab_Burge
Most of the higher end tranny builders on 904 buy their custom high end race parts from Dave Smith at Pro Trans, he has them built and wholesales them to other volume dealers Call him first for the best selection and prices 661-940-7400
