#2401602 - 11/10/17 06:55 PM Overheated Rotors From Racing
Chargerfan68 Offline
Loc: New York, USA
How many of you racers have your front disc brake rotors turn bluish after a season or two if racing. I run the stock single piston slider type (non pin type) with all new rotors and components. I notice after every track day they get more and more expaned area of bluish. Rotors were true and new pads with normal drag. All contct surfaces lubed with brake grease.
Is this normal occurrance just from the nature of slowing from 125 + speed? I dont jump on brakes. I always apply moderate pressure for a few seconds to scrub off some speed, let off a few back on slightly, etc. so i purposely dont overheat them
Anybody have perfect rotors after a season of racing or is this normal?
#2401615 - 11/10/17 07:26 PM Re: Overheated Rotors From Racing [Re: Chargerfan68]
rickraw Offline
Loc: Ambridge, Pa.
My rotors did the same thing. It's part of racing. Solid hardened non vented rotors only lasted a couple yrs + street driving.
#2401616 - 11/10/17 07:26 PM Re: Overheated Rotors From Racing [Re: Chargerfan68]
CMcAllister Offline
Loc: Fulton County, PA
We had a lightweight 2 piston front kit on a car a little over half as heavy as yours and we would discolor the rotors, especially after a visit to a short track where you really had to use them.
Regular inspection for cracks or heat damage, both on the rotors and pads, and paying attention to signs of warping and pulsation is a good idea. Discoloration by itself is mostly normal. Like anything else, repair or replace used up parts.
#2401654 - 11/10/17 08:35 PM Re: Overheated Rotors From Racing [Re: Chargerfan68]
MoparBilly Offline
Loc: Phoenix, AZ
Do you have a proportioning valve? Just wondering if have too much front bias...ask me how I know.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
#2401657 - 11/10/17 08:37 PM Re: Overheated Rotors From Racing [Re: Chargerfan68]
Al_Alguire Offline
Loc: Rockville MD & Las Vegas
Its not that unusual especially if you race the top end a lot.
#2401714 - 11/10/17 10:27 PM Re: Overheated Rotors From Racing [Re: Chargerfan68]
Dave Hall Offline
Loc: Cotati, CA
Most drag cars are reverse proportioned, street cars are not. You will definitely go through some rotors with a front bias brake system. I wouldn't change to drag car proportioning if I drove the car on the street. I would deal with buying a pad and rotor supply.
#2401740 - 11/10/17 11:30 PM Re: Overheated Rotors From Racing [Re: MoparBilly]
Loc: New York, USA
I do have a wilwood proportioning valve adjusted properly for the street (because i do drive it on the street and highway).
Thanks for the replies
Edited by Chargerfan68 (11/10/17 11:30 PM)
#2401991 - 11/11/17 01:49 PM Re: Overheated Rotors From Racing [Re: Chargerfan68]
CMcAllister Offline
I have never had to use an adjustable prop valve on a car that had properly designed and sourced parts. Buy a correctly sized good MC with a known bias instead of a $15 piece from Autozone, match the brake kit to the car (weight, speed, tire size, etc.) and pay attention to things like bore sizes and it just works. Hint: Wilwood and other manufacturers calipers may look the same, but the bore sizes are often quite different and as a result, they don't work the same.
#2402307 - 11/11/17 10:09 PM Re: Overheated Rotors From Racing [Re: Chargerfan68]
hemi-itis Offline
Loc: Great Neck,LI,new york
Dana drums out SSBC 4 piston calipers stopping 3900 lbs from over 130 for 10+ years and still have plenty left.Street driven over 1500 miles a season
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
PaRAicE is melting
#2402329 - 11/11/17 11:07 PM Re: Overheated Rotors From Racing [Re: Chargerfan68]
Loc: New York, USA
You sure its only 1500 miles a year? I would think 4-5k since your at every show and event with the hemi on the island. Haha. That's a compliment by the way.
#2402342 - 11/11/17 11:28 PM Re: Overheated Rotors From Racing [Re: Chargerfan68]
hemi-itis Offline
You are right I never exaggerate my numbers.
Some guys do for some reason,maybe to make themselves feel better.I have beat all my best e/ts and MPH last time out a few weeks ago aT LVr.
PaRAicE is melting
#2403387 - 11/13/17 11:58 PM Re: Overheated Rotors From Racing [Re: Chargerfan68]
Loc: New York, USA
I always love seeing your car at the events when i do get out to them. It proves that not only the newer cars can be driveable and reliable. And congrats on the bests!
#2403461 - 11/14/17 09:52 AM Re: Overheated Rotors From Racing [Re: Chargerfan68]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
My Aerospace front discs are blued and cracking. Obviously time to replace them. Of course my car is a 3900 lb sled that traps 150+ mph, so it's hard on brakes. I need some rear discs bad...still running factory 11" drums on the back.
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 446" w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'01 Ram 2500 QCSB 4x4 Cummins...toy hauler
'16 Grand Caravan SXT...baby hauler
#2403654 - 11/14/17 04:47 PM Re: Overheated Rotors From Racing [Re: an8sec70cuda]
Loc: New York, USA
How many years did you get out of them? 150+ is flying. My friend with a 70 ss chevelle jusr finished putting on 4 wheel aerospace and traps about 136. Wondering how long he'll get out of his at about 3600 lbs.
#2403897 - 11/15/17 08:28 AM Re: Overheated Rotors From Racing [Re: Chargerfan68]
Gotten quite a few years out of them b/c I don't race anywhere near as much as I used to. I think I got about 2 seasons out of them when the car was running mid 9s at 140 mph...and when I was able to go to the track fairly often.
I had a caliper seize up after 4 years or so. Bought a replacement and got the old one rebuilt...still have it on the shelf.
CHIP
25,150 Registered Members
186,828 Topics
Renault Le Car - "It's like a car, but it's French"
by SeaninSD
34 seconds ago
Funny photo of the day!!
by MidPenMopar
55 minutes 37 seconds ago
Indoor swap meet west bend wi - tomorrow
by NTOLERANCE
Today at 01:31 PM
Difference in M and H e body harness.
by fastmark
Today at 01:30 PM
