511 project falls short update #2401547
11/10/17 08:02 PM
11/10/17 08:02 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Temps are dropping fast this year here, but ran the car a couple times in 40* temps. Creeping up on the dominator tune. Richened the t slot and leaned the pvcr and added timing. Made it very happy. Playing with air bleeds now as i still have a lean issue on the pri at rpm. Im thinking adding jet to pri and reducing secondary a couple. Just need another nice day.
Re: 511 project falls short update [Re: mopar dave] #2401568
11/10/17 08:38 PM
11/10/17 08:38 PM
New York, USA
Chargerfan68 Offline
New York, USA
Most just slap on a dominator and mess with jetting and call it done, suffering with miserable part throttle driveabilitu and fouled plugs. Its amazing how crisp and clean a 1050 can run on a street car once you dial in the right settings inside the carb as well as bleeds. My 1050 actually runs cleaner than my 950 hp because i spent more time dialing it in. I dont think ill ever go back.
Re: 511 project falls short update [Re: mopar dave] #2401575
11/10/17 08:57 PM
11/10/17 08:57 PM
Don't be afraid to run it at or above 14.8 AFR on pump gas at light part throttle cruise from 1500 to 2800 RPM up scope
Re: 511 project falls short update [Re: Chargerfan68] #2401675
11/10/17 11:59 PM
11/10/17 11:59 PM
Mt Morris Michigan
Mt Morris Michigan
Absolutely. I believe all carbs come with the t slot open. On a Dominator it needs to have a jet in it if ya want good clean drivability. I now have a .056 jet in mine. Works great. Dom showed me that one.
